It is currently Tue Nov 24, 2026 1:14 pm
 Post subject: Thinking again hmmmmm
PostPosted: Sat Apr 25, 2009 2:18 pm
This is another example of an idle mind is the devils playground.
I know it is stupid , but came to mind , what if you put like a cpu cooling fan at the end part of the air cleaner for the air ducting . and wire it to come on when running. :roll: . ridicule at will :D
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Sat Apr 25, 2009 2:23 pm
You'll have less airflow as it will be more of a restriction than help.
PostPosted: Sat Apr 25, 2009 2:30 pm
Thats true , I was cleaning up some , came upon one , and everything I find, I think can this be used somehow.I know I think too much
Dave
81 Dodge D150
PostPosted: Sat Apr 25, 2009 2:31 pm
Car Model: 1967 Dodge Dart GT
i thought the same thing when i discovered they were 12v, but in addition to blocking the airway i dont think they spin near fast enough to do anything. i briefly thought about wiring one to my amp to keep it cooler, but never did that either...
PostPosted: Sat Apr 25, 2009 2:36 pm
Mount it on your dash for summer, cheap non AC car alternative. Get some hi-tec in that old car
8) :D
<img src="http://farm4.static.flickr.com/3173/2992308402_5481afb26e_t.jpg">
PostPosted: Sat Apr 25, 2009 2:40 pm
8) :D
note to self............ buy a dozen cpu cooling fans. :)
Dave
81 Dodge D150
PostPosted: Sun Apr 26, 2009 5:59 am
Plumb your air conditioner into the air cleaner for a nice blast of cold air!
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Sun Apr 26, 2009 6:41 am
Now you are being silly ( I don't have A/C) :)
Dave
81 Dodge D150
PostPosted: Sun Apr 26, 2009 7:47 am
There is a comercially made devise that dose exactly what you are suggesting. It has a small fan that ducts to your air intake and they claim more MPG and power. Ha the fan is smaller than a ps fan!
PostPosted: Sun Apr 26, 2009 8:05 am
get a small solar panel and fabricate a housing for the panel and the CPU fan and build a device which will fit over a mostly rolled up window to circulate air in the car while it is parked.
PostPosted: Sun Apr 26, 2009 8:18 am
Modern day swamp cooler?
PostPosted: Sun Apr 26, 2009 9:23 am
You mean like this? I think the cpu fan might work better.
http://news.cnet.com/8301-10784_3-6079960-7.html
PostPosted: Sun Apr 26, 2009 9:27 am
Yeah!
