It is currently Wed May 20, 2026 12:26 pm
 Post subject: Header Wrap
PostPosted: Mon Apr 27, 2009 10:09 am
Site Admin
I tried something novel. I read the instructions on the can of DEI Sealer for the header wrap.
It says to cure at 400°F
That's all fine and good, but the dual dutra headpipe I built won't fit in the oven, and even if it could, I don't think being beaten to within an inch of my life by a crazed woman for sticking it in there is going to fly.
Any thoughts on the curing process? I think I'm stuck with ambient curing for this. Good enough, or do I need to create a curing chamber and employ my turkey fryer burner? :shock:
CJ
PostPosted: Mon Apr 27, 2009 10:50 am
Do you have a heat gun you can stick in the pipe?
PostPosted: Mon Apr 27, 2009 11:12 am
Site Admin
That I can do. I'll go check it out of the shop for the evening! Good idea!
CJ
PostPosted: Mon Apr 27, 2009 11:46 am
Glad to be of assistance!
PostPosted: Mon Apr 27, 2009 3:38 pm
Wouldn't running the engine do the trick?
PostPosted: Mon Apr 27, 2009 4:32 pm
:shock: Supposed to seal these things? Just wraped mine and then saw this..
Not done yet so don't try to be funny and point out the zip ties!!!
TF
Even in moderation i am excessive!
PostPosted: Tue Apr 28, 2009 7:01 am
Site Admin
The heat gun got things nice and warm, but I'm not sure how "Hot" It got. Certainly not 400° with an ambient temperature of 60° in the shop.
I let the heat gun run for about four hours. Tonight I'll mount the head pipe up and then fire the Engine for a bit. Not hot, just put a bit of heat to it, then let it soak.
Battle of Detroit on Saturday at Woodburn! :D That's a fun race! The High School series is also going on that day, so the track will be hopping.
Gotta get this crate moving! :shock:
CJ
PostPosted: Wed Apr 29, 2009 6:08 pm
Site Admin
Tightened everything down tonight, and took a little drive. The engine compartment is considerably cooler.
The sound level in the car dropped remarkably. In the engine compartment it's considerably quieter also.
An added benefit! :D
When I was tightening the head pipe to the rear dual, the wrench came down on the wiring harness. I knew I was in trouble right then and there. My temperature gauge doesn't work anymore. :cry:
At least I know what happened. Time to run a new wire.
Dang.
CJ
PostPosted: Fri Jun 05, 2009 10:00 am
I have a Dutra manifold, and a modified manifold under the hood of my Volare. Would I see any benefit if I wrapped these manifolds?
This is a daily driver, not a race car.
Thanks for ya'll's opinions!
'78 Volare 225
'67 Charger 318
