It is currently Thu May 21, 2026 2:22 am
 Post subject: Weight & quantity of oil
PostPosted: Wed Apr 29, 2009 9:05 am
Several questions:
Is 90 weight gear oil + additive for Suregrip OK for 8 3/4" rear?
Dextron III ok for A 904? (Non racing car with oil cooler)
Dose cast deep base add extra two quarts of transmission fluid over factory pan?
PostPosted: Wed Apr 29, 2009 10:46 am
Several questions:
80W-90 is more common and superior in most cases to SAE 90. GL-5 with the additive or GL-5+ can usually be used without the additive. No additive needed if you don't have Sure-Grip.
Dexron III is fine.
Capacity depends on the pan. I feel it's a waste of time and money at this performance level.
PostPosted: Wed Apr 29, 2009 11:42 am
Thanks Josh
Came bolted on the darn transmission when I purchased the car.
