It is currently Tue Jun 09, 2026 6:52 am
PostPosted: Thu May 10, 2007 5:23 pm
I've been talking with someone at an aftermarket parts company about some other things, and I thought as long as I have his ear, I might ask if they'd consider tooling up for a line of fabricated aluminum valve covers. These valve covers would be laser cut from sheet aluminum, folded, and welded. I'd be sure to explain the importance of good baffles and making it compatible with a closed PCV system. But before bringing this up, I wanted to see if there was any interest in such a thing. So, would anybody here be interested in buying a fabricated aluminum valve cover if it were a good quality piece and sold for $200 or less? Any particular features you'd want on it?
I can't promise I can make this happen, but I wanted to see if anyone was interested, given the shortcomings of many of the aftermarket slant six valve covers.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
 Post subject: Valve covers
PostPosted: Thu May 10, 2007 6:38 pm
I did the same with Jeff Johnston Billet fabrications a few years ago. $800 for 1 or $200 for 20 or more. that was 5 years ago. I would pay $200 for one. Make sure to have clearance for roller rockers.
PostPosted: Thu May 10, 2007 8:26 pm
How thick would the sheets be?
PostPosted: Thu May 10, 2007 8:47 pm
IIRC, there is a company in Australia that builds them now. :D
PostPosted: Sat May 12, 2007 4:57 am
Good question; they'd probably be about the same thickness as the stock stamped steel pan but I hadn't brought that up. I did mention this idea to the company I was talking to, haven't heard back yet. I'll let you know if they do end up making them, if they don't announce it everywhere first.
PostPosted: Mon May 14, 2007 12:11 pm
an oil filler cap would be a nice option. most of the chromed ones I have seen are missing a filler opening. :shock:
PostPosted: Wed Apr 29, 2009 8:28 pm
Slantzilla, can you tell me who the company is? I have googled it and searched this site high and low.
PostPosted: Thu Apr 30, 2009 5:27 am
I'd be interested in one depending on the price.
PostPosted: Thu Apr 30, 2009 9:53 am
Interesting. I am looking to go away from chrome. ALuminum is better on the heat.
Id it has a cool "/6 powered" or "Mopar Powered" or something might be an interesting option, but even just Aluminum I would do
My Car Domain
PostPosted: Thu Apr 30, 2009 7:36 pm
Has anyone considered a valve cover than has a hinge set-up half way up the height of the cover. Essentially you would have to seal the bottom like you normally do, and were the oil can pool on the bottom, than you would have a "door" top half that you can swing open to adjust the valves. Just throwing ideas out.
PostPosted: Fri May 01, 2009 3:05 am
I do not remember who it was. The Cox brothers were trying to become a distributor for them though. :shock:
PostPosted: Fri May 01, 2009 4:15 am
Offy ones here (in Oz).CLICK
Is that what you were thinking of?
regards,Rod :D
