It is currently Fri Jun 05, 2026 2:57 pm
PostPosted: Fri May 01, 2009 5:00 pm
An acquaintance has a 1960 Valiant in which a later model steering column has been installed. The column is from a column shifted automatic which, of course, would be a 65 or later though she was told it was from a '62. The question is can she easily remove that column and put in the correct column from a 60 or 61 car. I know the steering gears were different but I'm not sure about the coupler or the length of the column. Is it possible or likely that the K-member and steering gear from a 62 or later has been installed to accomodate the later steering column? The car is in Tucson so I'm not able to easily go inspect it.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun May 03, 2009 6:06 am
No ideas or thoughts?
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
 Post subject: 60 valiant
PostPosted: Sun May 03, 2009 8:09 am
David,, I read that post---
on for a bodies only a guy has a 61 lancer wagon & 61 valiant parts car-- maybe he would help.
http://www.forabodiesonly.com/mopar/sho ... hp?t=61325
I commend you on helping, but this situation is fairly vague & without more complete info -- your shooting in the dark.. The diameter of the shaft on 60-61 cars is smaller thant 62- up cars-- so I'm not sure how they modified this to fit.
It would be nice to see an underhood pic to id the steering unit being used. Lawrence
PostPosted: Sun May 03, 2009 4:17 pm
I agree that an underhood pic would probably clear up the issue; I'll ask her again to provide that. My thought was that the later K-member had been swapped in along with the later steering gear and linkage. I don't know if that's even possible but I've heard that it is.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
