It is currently Mon Oct 26, 2026 6:15 am
 Post subject: Oil burning
PostPosted: Sat May 02, 2009 11:04 am
Took delivery of the RSA Valiant Charger this week - did the whole service lash etc - compression is good - 125 - 128 psi but it is burning oil - if you rev it it increases - let go it decreases rev again and big smoke - rings or valvestems? car sat for a long time engine is tight for a 67000km car
BTW this thing is VERY torquey -
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sun May 03, 2009 6:15 am
It sounds as though the oil rings may be stuck. Often a few hours of operation will free them up and reduce the smoking. Typically if it's valve seals you will see smoke when starting the engine after letting it sit for a while. Elsewhere on the board I believe there is a recipe for an engine flushing soup which you might find helpful. It certainly wouldn't hurt anything to replace the valve seals too.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun May 03, 2009 7:25 am
I have the same feeling - I didnt replace the valve cover after lashiong the valves - and I noticed one or two seal not looking kosher :?
I had the advice to pour some WM Penn Valve ease down the carb as well.
Have flushed Wil do so again! - was thinking aboput pulling the head and checking out the cylinder bores - have the gaskets
Regards,
Fanie Gerber
PostPosted: Sun May 03, 2009 8:14 am
I would run some Rislone to help free up the oil rings for a oil change or two. They should seal right back up. It never hurts to install new valve seals. I saved many old SL6 Valiants and Darts when I worked at Bellingham Auto Wrecking during my college days. You can use a half a quart of tranny fluid, but Rislone or synthetic oil are much gentler.
PostPosted: Sun May 03, 2009 9:27 am
Use soup if you can get all the ingredients or reasonable substitutes.
 Post subject: update
PostPosted: Tue May 05, 2009 4:37 am
Did the flush again - pressure (in psi) up less smoke
#1 150
#2 162
#3 140
#4 155
#5 140
#6 150
Regards,
Fanie Gerber
