It is currently Thu May 28, 2026 1:56 am
 Post subject: 3.91 form a Dakota
PostPosted: Wed May 06, 2009 10:11 am
Hi, Has anybody put a diff out of a Dakota into a Plymouth Caravelle(same as a Volare.)
I just swaped a 904 out for a 4 speed.
The car has 2.76 gears and it don't like it at all.
I have this 3.91 posi and I think it would be a great gear.
Any thoughts?
Thanks,Barry
PostPosted: Wed May 06, 2009 10:27 am
Is this a 7 1/4 rear end?
I switched from 2.76s to 3.21s (7 1/4 to an 8 1/4) with a 3-speed manual and it was much better from a stop without being too loud or wound out on the highway. I'd hate to drive much over 50 MPH for very long with 3.91s.
Also, which 4-speed? The 2.66 1st gear is going to be significantly worse off the line that the 3.09 1st gear used in the A833OD and the old six cylinder boxes.
PostPosted: Wed May 06, 2009 10:33 am
What 4-speed is it?
Close ratio, wide ratio or OD?
 Post subject: 3.91 from a dakota
PostPosted: Wed May 06, 2009 1:09 pm
The trans is from a 1973 dart V8 car. I presume it's a wide ratio 883
 Post subject: 3.91 from a Dakota
PostPosted: Wed May 06, 2009 1:14 pm
Hey Doc, a little off subject but have you heard of a guy named Don Dulmage? I just heard of him this weekend. He is building a ? six dragster with six snowmobile carbs.
I'm hoping to meet him as he lives about an hour from me. I'm in Cornwall Ontario Canada. One hr. from Montreal.
Barry
PostPosted: Wed May 06, 2009 1:24 pm
Joshie,The 276 is a 71/4 The 4speed from a dart V8. I've also heard of guys taking the 355 gear set from a dakota and putting them into the 81/4 housing. They change the carrier brgs and new mopar crush sleeve .
Sounds almost to easy!!!!!!
PostPosted: Wed May 06, 2009 1:40 pm
No, I do not recall talking to Don... I would have remembered the six carb deal. :P
If it is really a 1973 833 4-speed, it would have a 1 to 1 final (4th) gear.
You really should find-out if it is the close or the wide ratio box, (2.66 vs 3.09 1st gear) because that will impact your rear-end gear selection.
A manual shift SL6 needs about 10 to 1 reduction to come-off a standng start well. That is why the factory used 3.23 with the wide ratio 833. (3.09 x 3.23 = 9.98 )
This is also why 3.91 were common with the close ratio box. (2.66 x 3.91 = 10.40)
If I had a close ratio 4-speed combined with a SL6, I would likely be using the 3.73 rear gear (9.92 ) or a 3.55 (9.44) and put-up with a slower start-off for better high speed driving "manners".
PostPosted: Wed May 06, 2009 2:42 pm
The 4-speeds from the V8 cars are generally the close-ratio (2.66 first) boxes.
Are you thinking of swapping the entire rear axle assembly from a Dakota? That'll be a lot of work. Spring perches, overall track width (tire/body clearance), wrong wheel bolt pattern (most Dakotas had a 6-lug pattern), etc.
 Post subject: Re: 3.91 from a Dakota
PostPosted: Wed May 06, 2009 6:10 pm
Barry
http://www.slantsix.org/forum/viewtopic.php?t=30802
 Post subject: 3.91
PostPosted: Fri May 08, 2009 12:38 pm
Hi folks, sorry I haven't replied back.
My idea was to swap the dakota diff as one unit. It has the 5 bolt pattern and fits std wheels.
I spoke with a .
local fellow last night and what he did was take the carrier out of the dakota(3:55) and put it into an 81/4.
He had to change the bearings on the carrier and ajust the shims on the pinion.
The brgs were around $50 and he had the pinion set at a cost of $100.
No bad in Canadian funds.
I happen to have all the parts from a dakota (3:55 and a 3:91 Posi) so I'm going to give it a go!!!!!!.
My only dilemma is I want to get rid of the rubber insulator on the axle.
I think I'll need the shock mount from adifferent car! Any suggestions
I spoke With Don Delmitch? He has the dragster up and running again after a bent push rod problem.
He was very helpful and knowlegable on the slant. A new friend indeed.
Thanks for the input and help.
Dan, I'll call you for some lights for the 56.
Barry
PostPosted: Fri May 08, 2009 1:16 pm
As they did in the old A bodies they used both 7-1/4s and 8-1/4s in Dakotas; and 5 lug til 1990; 5 on 4-1/2" pattern;
but from what I read here I HOPE that the plan isnt to try and swap carriers between 7-1/4 and 8-1/4 housings; now THAT won't work.
PostPosted: Fri May 08, 2009 2:02 pm
I seem to remember our 89 Dalota with 5 lug wheels being 5x 4.25 or some such. It was like the Volvo size.
There is no way our 89 Dakotoa 7.25 is a smart swap into anything. Nothing crosses over to A bodies.
PostPosted: Fri May 08, 2009 2:44 pm
He's got a Volare, but I think the Dakota rear end will still be too wide. My 5-lug Dakota was 5 on 4.5". I had cop car wheels on the back for a while.
PostPosted: Fri May 08, 2009 4:12 pm
Yup; I ran squad car wheels on mine too. Mine was a 90, swapped a 8-1/4 in it in place of a 7-1/4, after my brother in law bought the truck from me and grenaded the rear end.
 Post subject: 3:91
PostPosted: Sat May 09, 2009 4:54 am
The plan is to swap a dakota 81/4 355 gear set into an 8/14 diff from a fifth ave.
