It is currently Sat Nov 14, 2026 12:36 am
PostPosted: Sun May 10, 2009 4:20 am
Hello!
Got an oddball application for a Mopar sparkbox that I'd like to trigger using breaker points. I heard (somewhere?) that this can be done.
Can somebody help me out here?
Thanks,
Jeff
PostPosted: Sun May 10, 2009 9:19 am
The only electronic ignition boxes I know of that will trigger from points are some early Toyota igniters like the one in my '75 Celica and many aftermarket ignition boxes that have a points trigger wire.
PostPosted: Sun May 10, 2009 11:21 am
Well, I found this:
http://www.gofastforless.com/ignition/electronic.htm and
http://www.gofastforless.com/ignition/points.gif
But I have not tried it, so.......
PostPosted: Sun May 10, 2009 11:51 am
Great! Just what I wanted. Thanks, Rust Collector.
Jeff
PS: I'm going to install it on a three cylinder Merc outboard motor.
PostPosted: Sun May 10, 2009 12:11 pm
well, I guess it is worth a try...but I won't guarantee it works.
have fun anyway
PostPosted: Sun May 10, 2009 2:07 pm
Dats veerd.
PostPosted: Sun May 10, 2009 3:48 pm
Jah, but der parts for dis motor ist expen$ive! Gott im himmel! A rotor (if you can find one) costs $200; a cap $150, and a spark box $400!
I used a Chevy (sorry!) marine distributor and common NAPA parts (a 6 cylinder cap and rotor) to make the 3 banger run. I'd lie to improve the spark AND get rid of the points, so... Per the article, the points last forever firing the Mopar black box.
Jeff
PostPosted: Sun May 10, 2009 6:35 pm
OK, so what's the application?
