It is currently Sun Jun 14, 2026 9:15 pm
PostPosted: Mon May 11, 2009 12:22 pm
The auction linked in this post contains this engine photo:
I can't make heads or tails of that large-diameter hardline connected to the intake manifold vacuum tap via…a filter or sensor or switch or somesuch. Way too big to be climate control, and these trucks didn't have vacuum-operated heaters anyhow. Truck doesn't have power brakes. Anyone got a clue?
 Post subject: slave cylinder assist?
PostPosted: Mon May 11, 2009 12:52 pm
It doesn't look stock, but it also looks like it is going down to the slave cylinder area. I used to own a 225 3 speed 66 D100. Does the slave cylinder have an assist?
PostPosted: Mon May 11, 2009 1:34 pm
Maybe its me, but it looks like the tube flattens out and passes under the upper bolt on the trannsmission side of the engine to transmission brace.
That is a funky throttle linkage too.
PostPosted: Mon May 11, 2009 1:47 pm
I've asked the seller for larger engine photos — don't imagine he'll send them, but we'll see.
Throttle linkage is funky but stock.
PostPosted: Mon May 11, 2009 3:27 pm
Maybe a GM tranny under there???? Pretty odd that is for sure.
PostPosted: Mon May 11, 2009 3:38 pm
Looks like the vacuum line to a Hydro-Vac.
PostPosted: Mon May 11, 2009 3:54 pm
Truck has a 4-speed <i>manual</i> transmission. And no power brakes, according to the owner (who may not know correctly).
PostPosted: Mon May 11, 2009 4:14 pm
An old vacuum activated PTO or Two Speed?
PostPosted: Mon May 11, 2009 4:36 pm
http://www.bendixvrc.com/itemDisplay.as ... entID=3246
PostPosted: Mon May 11, 2009 4:40 pm
Mmm, veddy eeeenteresteenk. I believe you've nailed it — would be easy for an owner who doesn't know much about vehicles to miss these power brakes on a cursory underhood inspection.
PostPosted: Mon May 11, 2009 4:44 pm
Its easy for a daily driver of these vehicles to not notice the power brakes.....
I was tipped off by the Camper Special designation..
www.sweptline.org is a wealth of info on these.
The wife has a 66 D100 with a Volare front suspension.....
PostPosted: Mon May 11, 2009 6:38 pm
Power brakes was the first thing that popped into my pea brain too. Lots of old trucks had that stuff under the driver's floor. :shock:
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 7 guests
