It is currently Fri Jun 19, 2026 4:26 pm
PostPosted: Thu May 14, 2009 5:47 pm
I have a couple of combustion chamber questions to ask:
1. Last week i cc'd my cylinder head and i ended up with 59cc chambers, is that some what normal for the SL6 combustion chamber to be that much larger than the spec 54cc chamber?
2. I plan to mill the heads approx 0.033" to get back to 54cc size, (so that i will have a CR of 10.25:1 with the k1/Wiseco setup). Will it be safe to use NGK ZFR5N extended tip spark plugs with this combo, or could i be running the risk of the piston hittng the plug? Would i even notice/see any performance difference over using the extended tip as compared to running a regular NGK GR5?
Thanks, Owen
PostPosted: Thu May 14, 2009 5:55 pm
Yes.
We cant know. I suggest trying both. I like the ZFR5N and use it ,,,,,,but I doubt I can quantify my results.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
