It is currently Wed May 13, 2026 2:44 pm
Post new topic  Reply to topic  [ 38 posts ]  Go to page 1 2 3 Next
 Post subject: not starting at all
PostPosted: Thu May 14, 2009 11:16 pm
hey hows it going everybody....im new around here
well down to biz
i have a 73 scamp that is in amazing condition for how much i paid for it but it wont start
when i decided to buy hte car(from a neighboor) it started easy and even on a push button
well 3 weeks later and its outta gas and i have the money..
now it wont start!
oput gas in it and it wont even run off starting fluid
put new plugs in it and when gapped at.020 it gets little spark and none at .035
well we're thinking its the coil but we arent positive
were hoping its not the pickup in the distributor!
any suggestions on what to try?
i had to go out and get a multimeter since my last one broke and we quit for the evening afterwards
and a real dumb question
whats the oil capacity of my 73 sl6?
heres my new ride....one of many i spose
and for kickers..heres my project
PostPosted: Fri May 15, 2009 1:55 am
5 quarts on a fresh fill and filter.
Your spark problem does sound like either a weak coil or ignition module. Before you go replacing parts though, cover the basics. Make sure all the connections are clean at the module and coil, the engine & body ground is good, ballast, cap/rotor condition.
PostPosted: Fri May 15, 2009 10:29 am
added a new coil
fully charged battery
new rotor button and cap
and still NOTHING...
im getting spark but no engine fire
PostPosted: Fri May 15, 2009 10:47 am
You gettin gas to the carb?
Check your plug wires are in the right order.
<img src="http://farm4.static.flickr.com/3173/2992308402_5481afb26e_t.jpg">
PostPosted: Fri May 15, 2009 10:50 am
whats the right order...
i dont have a manual
and the carbs getting gas....this is driving me insane
PostPosted: Fri May 15, 2009 10:53 am
Any chance 4 legged critters have gnawed on some wires?
PostPosted: Fri May 15, 2009 10:55 am
PostPosted: Fri May 15, 2009 10:56 am
so in relation to the dist where do the wires go
and no little turds ate any wires...i wish that was the case.,.itd be an easy fix....ive been working on cars for years but this is kicking my butt
probably because its an easy fix and i dont think easy
PostPosted: Fri May 15, 2009 11:03 am
cylinders #'d 1-6 front to back should be a mark on the cap for #1
Clockwise rotation:
Cap Leads-------- Cylinder
1------------------------1
2------------------------5
3------------------------3
4------------------------6
5------------------------2
6------------------------4
PostPosted: Fri May 15, 2009 11:06 am
http://www.slantsix.org/articles/articles.htm
I think the electronic ignition articles show the setup
PostPosted: Fri May 15, 2009 11:10 am
Ballast resistor?
PostPosted: Fri May 15, 2009 11:32 am
right order now....still nothing
the ballast resistor is hot as hell though
could that be it?
PostPosted: Fri May 15, 2009 11:51 am
So the thing that went wrong if I read correctly was that the car was running fine-you ran out of gas-now car wont run.
Could be something in the carb now because of this...just a thought.
There are people here that are more carb savvy than I.
PostPosted: Fri May 15, 2009 12:14 pm
carbs getting gas...and the fuel pump works....
im running out of ideas
PostPosted: Fri May 15, 2009 12:41 pm
ok now im not getting and spark at all
