It is currently Wed Jul 15, 2026 10:14 am
 Post subject: Guzzi cars first 1/8th
PostPosted: Thu May 14, 2009 10:44 pm
Went to the 1/8th tonight,best of three passes was a 8.425 at 80.95mph,Had some tire spin so I think there is more in it,I havent done any tuneing or tweeking yet,surprised alot of people includeing myself,Mark
PostPosted: Fri May 15, 2009 6:04 pm
Very impressive time slip! Nice work Mark.
PostPosted: Fri May 15, 2009 9:17 pm
I drive this car every day,back and forth to work,2 miles,I trailer to the track 30 miles away because of the 456 rear end,so is this considered a street car?Slicks will be ordered tommorrow,Mark
PostPosted: Sat May 16, 2009 7:09 am
Awesome time, especially for a street car.
PostPosted: Sat May 16, 2009 4:12 pm
Trailered to track= racecar.
PostPosted: Sat May 16, 2009 4:54 pm
It's kind of an in between car. Not a real street car, but not a real race car either. :shock:
Call it whatever you want, it's your car. :D :D :D :D :D
It's still pretty fast. :lol:
PostPosted: Thu May 21, 2009 10:17 pm
DROVE it to the track,best was a 8.349 at 79.90,all motor,stock crank rods and pistons,very happy,now to start tuneing it,Guzzi Mark
PostPosted: Fri May 22, 2009 12:20 am
Sounds like you got a good launch! If you drive it to the track its a street car,not so if you trailer it. Still running the same gear as the first post?
PostPosted: Fri May 22, 2009 12:45 am
Nice running Mark! It would be sweet to see you run 7's in the eighth keep at it! :D
TF
Even in moderation i am excessive!
PostPosted: Thu Jul 02, 2009 9:19 pm
Still havent done any tuneing changes yet,working on launches shifting points and lites,ran high 8.30s tonight ,did get 4 passes,pretty good lites,.012,.003.077 and a .040,getting better,Guzzi Mark
PostPosted: Fri Jul 03, 2009 8:13 am
Good runs for sure, what rpm's are you turning with 4:56"s at the finish line? how tall are your tires? You should pick up a bit with fresh slicks.
I bet some v8 guys are surprised.
Good luck
Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Sat Jul 04, 2009 8:44 pm
Havent really looked at the tach tru the traps,,,will next thurs,tires are 26x8.5,quite a few mid 8,30s at 80 mph,with the 4.56s,,,Yes,the guy I beat in the new 6.1 Charger wasnt real happy,my run was with a passenger and I ran a 8.59 .003 lite,he ran a 8.88 with a .022 lite.I must have hooked better cause my 60 ft was 1.78,his was 2.15,Track gave me a warning for going too fast with a passenger....you cant go faster than 8,60 and i went 8,589 ,Guzzi Mark
