It is currently Sat Nov 14, 2026 4:39 am
PostPosted: Mon May 18, 2009 7:03 am
170-225. All years?
PostPosted: Mon May 18, 2009 7:50 am
I am going to go out on limb and say yes - they can use the same dizzy Broadly speaking you had points and Electronic triggers, smog dizzies and so on - race types with no vacuum advance, and adjustable and nonadjustable vac advance all over the place
BUT in Oz you also had Bosch and Chrysler Dizzies of both types..
According to application advance curves differs
Best Dizzy - my opinion - Chrysler electronic early to mid seventies with lighter primary spring, and adjustable vac can
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Mon May 18, 2009 8:32 am
I'm speaking of body, shaft length, etc., not guts. Thanx.
PostPosted: Mon May 18, 2009 9:21 am
Then you better formulate your questions properly and If you read my answer the answer was YES :evil: :evil:
Regards,
Fanie Gerber
PostPosted: Mon May 18, 2009 10:19 am
Never mind. This site has too much PMS for me. Thanx anyway.
PostPosted: Mon May 18, 2009 11:10 am
Okeh, folks, let's all have a nice cup of tea and a sit-down.
68Barracuda: You didn't need to bite his head off. It's not what you said, but how you said it; nobody likes to be dressed down in public. I'm sure your new baby is straining nerves at your house — they do that — but I'm also sure you didn't mean to whack Ganymede quite so hard right out of the box, right?
Ganymede: Your question was too vague for a good answer. If you wanted to know about the physical interchangeability of slant-6 distributors, you'd've had a better answer by saying so in the first place. It would only have taken maybe five or ten more words than you used; very easy. 68Barracuda's answer was quite accurate, but you hadn't asked exactly what you wanted to know, and nobody likes to feel as though his time was wasted in answering a question. This site does not have PMS (THAT'SNOTFUNNY!!!! :lol:), but if you ask a vague question it's really hard for those who want to help you to do so.
 Post subject: Roughly...
PostPosted: Mon May 18, 2009 8:37 pm
There are several variants every year made depending on the engine, tranny, emissions, etc...
All the body's fit (points, EI, ESC) regardless of year...
The hold down changed about 1979...previously they were a plate with a slot, then they went to the style like the Big Block have with a bolt and a "claw" to hold down a collar type plate...
Roughly Points Dizzy's are found up to about 1972-ish (depends on application), as guts go, they do not have adjustable spring stops to adjust timing. EI came into being for the 1973 model year and was gone 7 years later in most cars, and 10 years later in some trucks/vans...ESC with fixed timing coupled to a timing computer phased in around that time... there are several variants of timing in the EI distributors....the most recommended "stock" dizzy is the 1976 standard dizzy with the 11R governor, and not far behind it is the 1977-1980 super six distributor with the 9R governor...the 1973-1975 dizzy is an ok start for a stock motor.
If you have a 'bad' dizzy and are replacing it with another one of like type (point to point, EI to EI), then set engine to TDC on the #1 cylinder and install with rotor pointing to #1 tower then give it a try....
Good Luck,
PostPosted: Mon May 18, 2009 10:58 pm
I do apologize for my over reaction
Regards,
Fanie Gerber
PostPosted: Mon May 18, 2009 11:11 pm
170-225. All years?
I'm not much help for that, however if you have to buy one in the near future I can vouch for getting it from Old Car Parts Northwest
8811 South 208 St #2
Kent, WA, 98031
tel 206-300-1083
ocpnwi@gmail.com
SlantSixDan turned me on to them.
I just got my P/N 3874714 in the mail today ($80+shipping) and I'm very happy with it.
PostPosted: Tue May 26, 2009 7:01 pm
SSRN National Champion
I like the correct term for the part. No dizzys. boon dogs. bluupers. Please the correct name. What if I said I had a flymo going bad and need a speadfro to fix it. Or a volta going bad if is in the air. Call a iginiton coil that. A distributors that. please . Thanks Ron Parker
Bee Good Or Bee Gone
PostPosted: Tue May 26, 2009 7:14 pm
Ron, My flymo went out the other day.
You can get a speadfro from a-zautopartsdotcom part #170225
They gots voltas too.dunno w/air or w/out. tho :D
<img src="http://farm4.static.flickr.com/3173/2992308402_5481afb26e_t.jpg">
PostPosted: Wed May 27, 2009 1:35 pm
My flymo needs wheels...
PostPosted: Fri May 29, 2009 7:06 pm
I think the last time my dizzy went out was when Sandy brought down to much Canadian Moose mash. Thanks Ron Parker :D
