It is currently Mon Nov 16, 2026 6:07 am
PostPosted: Sat May 23, 2009 1:02 pm
What is the best way to remove the cables from a push button trans? Should I remove the cables at the trans (not sure how anymore) or should I remove the cables from the back of the shifter mechanism (which I have never messed with)? I am taking the engine and trans out as a unit and I am keeping the speedo cable in the trans. thanks...
PostPosted: Sat May 23, 2009 4:10 pm
Remove the cables from the trans. Why are you not removeing the speedo cable? It is actually easier to remove, then the cables. Call me if you wish.
 Post subject: going back under
PostPosted: Sat May 23, 2009 4:22 pm
Let me get back under there tonight and see what I can do. I found my old Valiant manual to see how the cable comes out of the trans. If I have any questions, I will call ya later. Thanks
PostPosted: Sun May 24, 2009 9:57 am
There is a little wire "clip" that holds the cable in the transmission, push the wire "just right" and the cable pops out.
The FSM does a good job showing how it's done.
Users browsing this forum: Ahrefs [Bot] and 3 guests
