It is currently Thu May 14, 2026 4:26 pm
 Post subject: Pistons
PostPosted: Fri May 22, 2009 12:59 pm
A set of pistons on EBAY, item # 390053955739. These are Chrysler factory pistons, and are dished!! P/N 2084390. Are these the "truck" low compression pistons?
PostPosted: Fri May 22, 2009 2:08 pm
Stock style pistons are cheaper at summit racing <$12 per slug.
11.02 @ 120.56
Chassis dyno
PostPosted: Fri May 22, 2009 2:35 pm
2084 390 = 0.020" oversize, export low compression.
PostPosted: Fri May 22, 2009 3:31 pm
Thanks Dan.
PostPosted: Sat May 23, 2009 2:28 pm
What are they...about 6:1 for a compression ratio?
11.02 @ 120.56
Chassis dyno
PostPosted: Sat May 23, 2009 2:37 pm
Don't believe I have that specification! 7 or 7.5 stands out in my mind but that might be out of thin air. Someone would have to do the math. Seems to me these'd be a great pick for a turbo setup...
PostPosted: Sun May 24, 2009 6:33 am
The normal pistons are good for boost but if these are 7:1 then they need 40 pounds of boost!!
11.02 @ 120.56
Chassis dyno
PostPosted: Sun May 24, 2009 6:53 am
Some of the later Slants were barely over 7.5 anyway thanks to Chrysler's tight machining standards. :?
PostPosted: Sun May 24, 2009 8:52 am
Sealed Power catalog.
LC244P 1.760 comp dist, resessed head .208 deep x 2.500 dia 7.0-1 comp.
244NP 1.740 comp dist, flat head, 8.2-1 comp.
PostPosted: Sun May 24, 2009 9:57 am
Get everything on the big side and you have a slug or get everything on the low side and it can run like a scalded dog.
My 340 is 9.4 to 1...advertised 10.25 and a mid 70s smogger 360 I checked was something like 7.5 to one.
11.02 @ 120.56
Chassis dyno
