It is currently Tue Nov 24, 2026 11:07 pm
PostPosted: Mon May 25, 2009 7:14 pm
Check it out:
Ebay auction I bought:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0143178329
I think the carbs are Carter BBS? This is my first time dealing with this manifold,any tips? :D
PostPosted: Mon May 25, 2009 8:29 pm
Yep, that's a pair of BBSs. See discussion of this manifold setup here, here, here, and here. I don't recall what year and model vehicle you're working with, but unless it's a '60-'66 slant-6 A-body (or a '60-'62 slant-6 big car), you'll have to custom-fabricate a throttle linkage. If yours is an automatic transmission, you'll have to fabricate a kickdown system as well. See this thread for kickdown options.
PostPosted: Mon May 25, 2009 8:53 pm
Its a 67. Just seemed like a good price.
PostPosted: Tue May 26, 2009 4:20 am
raPoM
Nice find!
Slantsix Dan directed me to the Bouchillon Kick-down Cable set-up, their throttle cable adapter, and I'm glad he did. You will find these two devices will more easily solve your adaption problems where your car is a 67', and has a cable operated throttle.
PostPosted: Tue May 26, 2009 12:39 pm
wjajr
Are you running the dual 1 bbls? I thought it was a nice find aswell :D Usually the seem to go for a bit more.
PostPosted: Tue May 26, 2009 1:45 pm
raPoM:
No. I'm using a Clifford 4v intake with a Holley 390 cfm 4v, and Clifford shorty headers. This what was on the car when I purchased it February 2008.
I have since changed out the manual valve body to a normal shifting VB which required the addition of a kick-down cable. I used the Bouchillon cable, per Dan, with their cable bracket that hooks to the carburetor. With my set up it was a no brainer.
PostPosted: Tue May 26, 2009 2:12 pm
Got ya! Thanks for the info. Anyone running dual carb set ups around here?
PostPosted: Sun Jun 07, 2009 2:05 pm
Hello, all. New to the site. I have the Offy 2X1bbl intake with Holley 1920's on my 225. I've run it on the street relatively trouble free for nearly 10 years. Once you get the jetting issues squared away, and find good carb cores to rebuild,the driveability is far better than the single 1bbl arrangement. I actually found the mileage to be better on the highway since the engine didn't have to work as hard to get up to and maintain speed as well. Plus, it's always nice to lift the hood & see peoples reaction when they see the dual carbs with the stock air cleaners in place. Probably not the most hi-tech induction system, but for a stock to mildly modded slant works very well.
PostPosted: Sun Jun 07, 2009 2:15 pm
They are very sweet. I just sold it to a fellow member,hope he is very happy with it. My plans go far beyond mild,so I think I will be going with the clifford.
PostPosted: Sun Jun 07, 2009 2:21 pm
Welcome to the site valiant64.
I bet that does look cool with the older style air cleaners.
74 Dodge Charger 225 factory A/C auto 1920 carb stock exhaust.
Mods;
HEI, MSD B3, Magnecor 8 mm, ZFR5N, .060 rotor, CH410X cap, new 3874814 dist, fuel mod, valves hot .010 & .020, all new hoses, JP chain, brake hoses and fluid.
PostPosted: Sun Jun 07, 2009 2:32 pm
BTW, as far as the Offy 2X1bbl intake is concerned, does anyone know where to get the Offy linkage kits for apps' with A.T.? I believe the part # is 5041K. Any help would be appreciated. :?:
 Post subject: Offy intake
PostPosted: Mon Jun 08, 2009 8:55 am
I ended up buying this setup. It's going on my '64 Valiant along with a swap of the auto to a 4-speed. My 225 is all stock and I think this will work well. The visual is pretty unique, and it should run better than the single 1-bbl. This is a job I look forward to.
SOLD! Went to New Zealand. '64 Valiant Signet 200, 2-dr hardtop. 225/4-speed/Pistol Grip, Offy 2-1bbl, Clifford headers.
Minimum government means maximum LIBERTY!
 Post subject: Re: Offy intake
PostPosted: Mon Jun 08, 2009 3:43 pm
I think that's a great setup! Congrats on the purchase.
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
PostPosted: Mon Jun 08, 2009 4:15 pm
Are you interested in selling your PB trans stuff?
PostPosted: Mon Jun 08, 2009 6:02 pm
Found the Offy linkage kit... :)
55' Dodge Stepside
64' Plymouth Valiant V100
67' Dodge Coronet 500
73' Dodge Dart Sport
Users browsing this forum: Google [Bot] and 10 guests
