It is currently Mon May 18, 2026 4:25 am
 Post subject: Mechanical pump question
PostPosted: Sat May 30, 2009 11:56 am
I just bought a brand new mechanical pump and hooked it up and I was only getting 2.5Psi max with no return. I'm assuming the lobe from the camshaft is wore out. How can I tell?
-- Mister Perkins --
Pictures of my truck
http://www.cardomain.com/ride/3257131p
PostPosted: Sat May 30, 2009 1:23 pm
Turn the engine over by hand using a wrench, not the starter!.......set up a magnetic base with probe and gauge and then turn it over and see how much lift it provides at the gauge.
PostPosted: Sat May 30, 2009 1:26 pm
how much lift is it supposed to have? isnt the stock lift .395?
PostPosted: Sat May 30, 2009 1:33 pm
For a stock cam at least .300 at a minimum. There should be about .380 to .400. It is the same as your other cam lobes. I have a used cam and just looked at it.
PostPosted: Sat May 30, 2009 2:01 pm
alright.. well I'll have to drag it down there tomorrow to confirm the lift on it.
Users browsing this forum: Amazon [Bot], Google [Bot] and 7 guests
