It is currently Tue Oct 13, 2026 12:10 am
PostPosted: Fri May 29, 2009 1:30 am
http://www.jegs.com/p/Mr-Gasket/Mr-Gask ... 3/10002/-1
Anyone use this item before? I'm looking at 720-97. I have a 1" carb spacer which I want to pull because the air cleaner *barely* fits-- I'd like to make it more certain.
I'm thinking of ordering 2 of these dissipators (1/4" tall each), and using a full one and half of the other to retain some of the spacer effect. Is this adviseable or is there something I'm not thinking about? Heck I'd just stack both of them fully if you fellas think it would work like a spacer, I'd still be cutting a half inch of carb height out of the situation. plmk if I'm forgetting something that would make this idea not work.
-Anthony
1962 Plymouth Valiant Signet 200
PostPosted: Fri May 29, 2009 7:07 am
I had one of those on a 383. It didn't work.
PostPosted: Fri May 29, 2009 2:04 pm
I have one on my 340. It doesn't leak, anyhow. I just was sent a Mr. Gasket rear main seal for my 340, which is marked 360 on the package. It is of a larger diameter, and can't be installed with crank in place. I plan to avoid Mr. Gasket if I see him again. :cry:
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Fri May 29, 2009 7:34 pm
Mr Gasket makes the Ultra Seal intake gaskets for the small blocks, excellent stuff!
PostPosted: Sun May 31, 2009 6:17 am
OK, maybe they just sent me the wrong one. :?:
PostPosted: Mon Jun 01, 2009 9:26 pm
So ultimately, does anyone think stacking two of those would create the same effect as a 1/2" spacer? Or should I just not bother and go with a 1/2" spacer?
-Anthony
PostPosted: Mon Jun 01, 2009 9:55 pm
Just a wood or phenolic spacer..........
aluminum spacer will heat things up.
PostPosted: Tue Jun 02, 2009 12:29 am
Yea, it's an aluminum 1" spacer I'd be pulling, for heat and height issues. I'll just go with a wood or phenolic spacer instead of that Mr Gasket doohickey, thx
-Anthony
PostPosted: Tue Jun 02, 2009 5:42 am
I'd say do it-- if your goal is to try and lower the carb height. The gasket sealing should not be a problem. With those choices it looks like you can adjust the carb height a little. Lawrence
Users browsing this forum: Amazon [Bot] and 19 guests
