It is currently Sat May 09, 2026 12:54 am
 Post subject: Need a motor ?
PostPosted: Sun May 31, 2009 5:35 pm
Hi i'm new to the club. I have been a Mopar guy for 30 yrs. I have owned mostly fast backs and Imperials. Although I have had 6 cyl Darts.
I bought my Daughter a 1967 Coronet 440 slant 6. It's spun a rod, need an Engine! Thinking about Kragens!
Thanks!
Cudaman, 1965 Cuda, 1967 Coronet 440 1962 Imperial
PostPosted: Sun May 31, 2009 6:02 pm
Welcome on the board. Don't buy a "remanufactured" engine (or any other working component) from Kragen or any other Davey Do-It-Yerselfer auto parts store. They are trash, despite the fancy (useless) warranty. You're much better to find and install a good used engine or find a rebuildable engine and have it reworked by a good, reputable machine shop. Any slant-6 engine can easily be made to work in your '67, you just swap on the original oil pan and oil pickup pipe/strainer, and if you use a '68 or later engine you need the torque converter adaptor ring from Pat Blais ( tflitepatty@verizon.net ). Check www.car-part.com for engines in your area. Searching '67 Coronet will find all the '60-'67 slant-6s. Searching '73 Dart will find the next newer group. Searching '82 Dodge Truck D100 will find the newest group. Ask more questions!
PostPosted: Sun May 31, 2009 6:28 pm
Start with Where are you located?
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun May 31, 2009 7:48 pm
Thanks I agree, just feel pessured by time..
PostPosted: Sun May 31, 2009 8:59 pm
castyman,
Don't be pressured. I was working 12 plus hour days plus a 4 hour commute and had my oil changed at a Valvoline Lube shop and the filter was faulty and delaminated inside and would not by-pass oil. 5:00 am on the way to work it failed about 20 miles into my 64 mile commute and starved the engine of oil. Wiped out two rods #1 and #2 and smoked the bearings.....
I was having the same kind of thoughts as you. Once I came to my senses, I pulled the motor and sent it out for various upgrades listed below. Thanks to the folks on this site with some their great advice I built a super motor for torque and mileage. It's been two years and 55,000 miles ago now. I look back and it was the best thing I could have done even though I had little extra time. By doing some of the work myself I saved alot. So hang in there.
That is a pretty sweet car you have. Fix it up!
Click on the red link below and you can take a look at mine. Getting her ready for some paint. :D :D :D
Last edited by Aggressive Ted on Sun May 31, 2009 10:07 pm, edited 1 time in total.
PostPosted: Sun May 31, 2009 9:57 pm
Thanks I agree, My teenage daughter is in a hurry, another lesson for her to learn! I will pull the crank and have the block checked!
Thanks...
