It is currently Sat Oct 10, 2026 9:23 am
PostPosted: Sun May 31, 2009 5:41 am
what should i use for my slant six rocket cover gasket cork high temp rubber or something else help i been bye mates but i want someone who knows wat there on about to help it was a cork one when i took it off
PostPosted: Sun May 31, 2009 6:21 am
e.e. cummings?
PostPosted: Sun May 31, 2009 6:47 am
either one will work well if the valve cover flange is flat and you do not tighten the crap out of the mounting bolts
PostPosted: Sun May 31, 2009 9:12 am
I prefer the rubber ones.
PostPosted: Sun May 31, 2009 4:52 pm
I use the rubber ones and some white grease........
Can reuse that way.
:wink:
PostPosted: Sun May 31, 2009 5:17 pm
e.e. cummings?
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Sun May 31, 2009 9:04 pm
I prefer the rubber over cork. They last alot longer and will reseal after a few valve re-lashing sessions.
PostPosted: Sun May 31, 2009 9:39 pm
Is that so even when you don't use white grease on them as well?
I did some research and bought the rubber gasket over the cork however I didn't use anything on my rubber gasket after I did my valves last week... :shrug:
PostPosted: Sun May 31, 2009 9:43 pm
I use just a little synthetic oil and the seat fine. Grease would work just as well.
PostPosted: Sun May 31, 2009 10:32 pm
Grease or oil is fine.
Dry they might stick...........
PostPosted: Mon Jun 01, 2009 5:35 am
Hard Charger you will be fine as long as you go ahead and take it back of an lube it now. It may or may not work if you wait 6 months.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Jun 01, 2009 8:40 pm
I have reused a rubber gasket many times over without any lube. Maybe I just got lucky? Looked in good shape every time it came off, so it just went back on.
PostPosted: Tue Jun 02, 2009 7:05 am
Online
I don't use any oil/grease and they reuse fine.
 Post subject: Brand?
PostPosted: Tue Jun 02, 2009 6:57 pm
Is there a preferred brand? The last one I used was a "CORTECO" from the NAPA store and the tabs were off a little bit. Not so far off I got the wrong part but like the mould or die was off a little bit. (Off far enough that only two of the four tabs lined up making installation a bit of a challenge.)
PostPosted: Tue Jun 02, 2009 9:12 pm
I use the felpro one....
look number up on rockauto.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 22 guests
