It is currently Fri Nov 13, 2026 11:44 pm
PostPosted: Thu Jun 04, 2009 4:43 am
On dual field alternators I can't tell from the wiring diagram which wire from the voltage regulator goes to which Field terminal on the alternator.
Does anyone have a way of telling? One wire goes directly to the voltage regulator and the other goes to the ballast resistor/voltage regulator. On the alternator (looking at the back of the alt. mounted normally) there is the output terminal at 1 o'clock, a Field terminal at 11 o'clok and another at 9'oclock, IIRC. Which wire goes to 9 o'clock and which goes to 11 o'clock?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Jun 04, 2009 8:20 am
It does not matter. 8)
