It is currently Sat Nov 14, 2026 5:49 am
 Post subject: torque converter bolts
PostPosted: Fri Jun 05, 2009 7:50 am
Just got a 87 dodge truck with a 225 and a automatic, but the bolts where all out of the flex plate into the torque converter, I replaced the flex plate, and got new bolts but I don't know if these bolts use lock washer or not. Can some one tell me if thay do or not, and what kind, and what these bolts get torque to. Thanks Petergun
PostPosted: Fri Jun 05, 2009 8:25 am
No washer. I generally use German torque on these. Gudentight. Realistically a plain 5/16-18 bolt is about 25 ft/lbs. General Tightening Torque Guide Also, a drop of blue thread locker on clean bolts going into clean holes will help keep them in place.
 Post subject: bolts
PostPosted: Fri Jun 05, 2009 11:29 am
Thanks guy, I very much appreciate your time and help. Pete.
PostPosted: Tue Jun 09, 2009 7:20 am
The heads on the factory bolts are only about half the thickness of standard bolts. Be carefull the thicker heads don't hit the block.
PostPosted: Wed Jun 10, 2009 6:16 am
The factory bolts are also grade 8.
Ffrank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
