It is currently Sat May 09, 2026 11:34 am
PostPosted: Wed Jun 03, 2009 7:14 am
Hi all,
Its been awhile for me, been busy in the Navy, took 9 days leave to come home and see the family fix the car and bring her back up to pensacola,fl. ran into a problem with the rebuild though. I need to track down a new cam kit, ersons out of cam blanks, not really to excited to pay 2X for a chevy lobe comp cam, so heres the question,
the engine is a '76, can I use a boneyard hydraulic cam and lifter set up on the mechanical head/block with out changing the cam bearings ??
I read an old hot rod article the said you can use a hydraulic cam with mechanical lifters to give you a broader torque curve, but thats for V-8's, would that work for the slant ?
Thanks all,
-Mike
PostPosted: Wed Jun 03, 2009 9:04 am
Oof! Any indication when they'll be back in stock?
Well…yeah, you could if you were to machine a groove in the rearmost cam journal (and also use the hydraulic-engine pushrods and complete rocker shaft assembly with bolts), but…why? The factory hydraulic cam is weak.
This sounds like a poor idea.
PostPosted: Wed Jun 03, 2009 11:30 am
1-2 weeks
because the only slants I have found were an '82 & '85 D-150's
well I said it was v-8's :D
-Mike
PostPosted: Wed Jun 03, 2009 11:34 am
What kind of cam do you really want?
PostPosted: Wed Jun 03, 2009 12:28 pm
mechanical + lifters 280 intake 270 exhaust 110deg lobe seperation
PostPosted: Wed Jun 03, 2009 1:49 pm
Narrower lobe separation than 110° is better for a 225.
Erson's advertised durations are a bit longer than other mechanical cams with similar .050" tappet rise duration numbers.
Having said that, Oregon Cam Grinding #346 is a mechanical with 234/228° at .050", .476/.479" lift with 1.5:1 rockers and is only 262/252° advertised duration which is checked at .020" lift. The lash is listed as .012/.012 so the effective duration is a likely a little more than advertised. It's ground on 106° lobe centers and 102° intake centerline which is near ideal for a 225. You can ask for a different centerline if/when you order.
Oregon Cam Grinding typically regrinds OE cams and charges $70 plus a $15 core charge., You'd have shipping on top of that. They did have some new slant blanks last time I asked. I have run a few of their cams and have always been happy.
http://slantsix.org/forum/viewtopic.php?p=218596
PostPosted: Thu Jun 04, 2009 5:35 am
If your OLD cam is in good shape Erson will regrind it to the 280/270. I was told we will get that at the slant 6 "discount" too.
Just a thought,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Jun 04, 2009 7:05 am
yea but I junked the cam, figured hell erson will never run out........ yea I'm a dumba$$
-Mike
PostPosted: Thu Jun 04, 2009 7:43 am
well just got off the phone with oregon, said they could have the cam ground in 1 day and sent out just as quick WOOO HOOOO !!! forgot about the time difference from florida-oregon, gotta call back in 1 hourand place my order.
Now joshie why do you reccommend a tight LSA ? This will be a NA engine, but will be getting turbocharged in the very near future, and erson reccommended the 280/270 110deg for turbocharged app's
-Mike
PostPosted: Thu Jun 04, 2009 9:17 am
The tight LSA is due to the large cylinders and small valves requiring more overlap to scavenge the cylinders. If you are not going to change the cam between now and when you turbo the car I would use a 110-112° LSA and live with the loss of mid range torque until the turbo is installed.
PostPosted: Sat Jun 06, 2009 8:09 pm
well the cam has been ordered, will be here next friday, but i won't be. Will be back up in pensacola tommorrow night, so the car sits, again, $#!+ I hate how nothing ever seems to go right, no matter how hard you try........
-Mike
PostPosted: Sat Jun 06, 2009 9:14 pm
What cam grind did you get?
PostPosted: Mon Jun 08, 2009 7:17 am
280 intake 270 exhaust 110deg LSA, with lifters shipped for $160.25, not bad still need 340 springs though......
-Mike
PostPosted: Mon Jun 08, 2009 7:34 am
Josh,
Did you design that #346 cam for Oregon? I was going to get one ground to exactly those specs myself - nice work. I will probably order one for the motor I just dropped into Slantkota.
Cheers,
PostPosted: Mon Jun 08, 2009 9:19 am
Lou,
Nope, Oregon had that grind already. Serendipity I suppose.
Mike,
I have a set 340 springs and retainers available if you want them. I won't be putting them to use like I thought. PM me if you're interested.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
