It is currently Sat May 09, 2026 3:10 am
 Post subject: Help Please
PostPosted: Sat Jun 06, 2009 8:50 pm
I have an 78 Aspen with a Super 6 and what I think is a 904 and 35,000 original miles . Well I was driving the car and over the last few days I had felt a strange jerking which felt like either the trans or ignition breakdown .
The problem I had today was I drove the car all day and parked it several times ( yard sailing) and went on to work , about 6 hours later I went to go home and when I put the car in gear it doesn't move .
I feel it hit reverse and drive right on time but it doesn't pull , the fluid looks overfull like the pump isn't working , and the fluid is clean and not burnt .
Please help me out on this and Thank You Jim
PostPosted: Sat Jun 06, 2009 9:03 pm
I forgot to mention it also misfired and stalled alot when shifting into reverse , but today it wasnt doing that .
PostPosted: Sat Jun 06, 2009 9:23 pm
Sorry to say that usualy is the pump going out and the stall in reverse is the torque converter locking up,because the pump can't apply enough pressure to release the converter
Nick
86 d150 turbo /6.
PostPosted: Sat Jun 06, 2009 9:49 pm
Thanks Ram thats what it thought when I saw the high fluid on the stick .I guess Ill have to take it apart I can only hope for a clogged screen . would you or anyone know if I could just change the pump or do I need a complete rebuild . Jim
