It is currently Wed Nov 25, 2026 2:11 am
PostPosted: Sun Jun 07, 2009 10:15 am
A local shop quoted about 1800 for a complete rebuild of a stock 1985 /6.
I think that is a little high. I have always wanted to try and do a build myself except for the machining part of the build. Is there any place that anyone knows of around NW Ohio that is 1: cheaper than 1800 and 2: knows what they are doing. If I end up doing most of it myself is there any kind of things that I need to look out for? I dont want anything fancy, just a stock rebuild that wont burn up oil and has decent oil pressure. Thanks for any help, Paul
PostPosted: Sun Jun 07, 2009 11:30 am
Does that include in milling? like decking the block or taking any off the head or pocket porting or balancing or 3 angle valve grind?
I paid $2,000 for the work listed above to hit 9.5 compression, plus regrinding the cam, head porting and Teflon coating on the pistons.
PostPosted: Mon Jun 08, 2009 6:09 am
I would say that price is about right. If they do ANY machine work at all it will add up to $600 at least plus $300 or so in "cheap" parts. Depending on whats actually done I would say thats fair.
Now if it were me and I was going to spend that I would do some cheap mods to "help" the power from the slant. If it has to go to the machine shop have them up the compression a little. I dont know how much you can mill off of the Hydrolic heads before you have problems. Maybe someone else can chime in about that.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: Bing [Bot] and 13 guests
