It is currently Sat Nov 14, 2026 3:47 am
 Post subject: A833 non syncro
PostPosted: Mon Jun 08, 2009 5:39 pm
Are all A833's non syncro when going down into first, or does that mean mine should be and the syncro into first is blown.
I can get back to first, if barely rolling, like 6 MPH, above that there is a bit of grinding. All up shifts are good.
If this is a non syncro unit, can it be rebuilt to allow down shifts to first,
I like that for wheeling in traffic. Tranny is in a 83 D-150.
thanks
PostPosted: Mon Jun 08, 2009 6:58 pm
A833s are fully synchronized in all forward gears. Downshifting is a tough job for the syncros as you have to speed up the clutch disc and input shaft when downshifting. This job is usually made tougher by people putting GL-5 in the box which is too slippery for the syncros to get a good grip. I would make sure you have the correct lube in the box and make sure there is no drag on the clutch. Redline MT-90 isn't cheap, but it worked great in my A833.
PostPosted: Tue Jun 09, 2009 12:07 pm
joshie is correct
i had the same problem with my 87 1/2 ton not wanting to downshift into first gear especially when it was cold.
i changed the tranny fluid to redline mtl and it really helped. now i can safely downshift without any grinding at around 12-15mph.
dean
PostPosted: Tue Jun 09, 2009 5:26 pm
the transmission has Dextron ATF in it,,, I'll give the redline a try
thanks
Users browsing this forum: Amazon [Bot] and 4 guests
