It is currently Sun May 17, 2026 2:17 am
 Post subject: Great !
PostPosted: Tue Jun 09, 2009 9:19 am
Great, I'm glad it worked for you.
Rick
PostPosted: Tue Jun 09, 2009 9:46 am
Thanks for the heads up on the donut gasket Ceej. If it leaks I'll replace it however if it does not leak then that's one more thing I won't have to fix.
Thanks!
1971 GTX 440, 727, 3.91, stock except cam
1972 Slant 6 mor-dor Dart stock except minor rust
1984 Dodge Rampage 2.2 OEM stock
1986 Plymouth Duster 2.2 OEM stock
2007 5.7 TRD Tundra, fast for a truck
stopping is cheap, going is expensive
PostPosted: Tue Jun 09, 2009 4:10 pm
Glad to hear you were finally successfull. I know how frustrating it can be working on a car in the heat. It's still 90 here at 7:10pm, but at least it's cooled off enough to do some light outdoor activities.
Scott.
PostPosted: Tue Jun 09, 2009 4:29 pm
Thanks Scott. Yeah, it's been hot these last couple of days and I didn't need that since I was hot enough considering the circumstances I was under lol.
I got the distributor out and am now cleaning it up getting it ready to go back in once my op gaskets arrive in the morning and the op is reinstalled. Everything is going smoothly now.
PostPosted: Tue Jun 09, 2009 6:13 pm
How does the oil pump look inside? Is it the stock aluminum pump?
PostPosted: Tue Jun 09, 2009 7:14 pm
Yes, stock alum pump. It looked great inside and checked out within tolerances. The pressure rv came out easily once I had the pump in my hand although it did have black deposits that also cleaned up with little effort. I slipped a 3/16 nut behind the spring for a little more pressure.
It's cleaned up and ready to go back in just waiting on gaskets.
PostPosted: Wed Jun 10, 2009 11:39 am
Just got back from a test drive and the oil pressure light never did flicker or come on 'cept when I went to start it. The op went back on with no problems and the distributor is adjustable now thanks to a total disassembly, clean, oil and proper point gap set at .020.
Just thought I would close this thread with the all ok report.
Many thanks to all that helped. :wink:
Users browsing this forum: Dart270 and 4 guests
