It is currently Wed Nov 11, 2026 12:52 pm
 Post subject: 833 Questions
PostPosted: Mon Jun 08, 2009 9:17 pm
Hello. I'm new to the SL6 forum. I happened onto the forum by finding the truly excellent 833 article. Thanks, guys! Great job!
Two 833 questions:
1) My 833 sometimes has to be forced into 2nd gear, both up and down. Doesn't really grind, just won't go in. There is plenty of clutch disc clearance. Is the problem likely the stop ring? Also, there is a note in the FSM about using #120 emory cloth to rough up the synchronizer cone in the gear when replacing the stop rings. Any opinions on that?
2) Are there any 833 mods that can be made to increase shifting speed.
Ron Evans
67 Barracuda
Long Beach CA
PostPosted: Mon Jun 08, 2009 10:24 pm
What lube is in the box? GL-5 is too slippery. Try Redline MT-90. If that doesn't fix it you'll have to open it up.
PostPosted: Tue Jun 09, 2009 9:13 pm
Thanks, Joshua.
I found a dealer nearby. It's worth a try.
Ron Evans
67 Notchback
PostPosted: Wed Jun 10, 2009 1:11 pm
passion performance sells a slick shift shift kit i think is what its called
http://www.passonperformance.com/
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Wed Jun 10, 2009 1:23 pm
The slick shift modification to the A833 is for racing only. It involves discarding the syncronizer blocking rings and taking every other tooth out of the clutch sleeves and hubs so you can speed shift the transmission. Unless you are building a dedicated drag car this is Not something you want to do.
PostPosted: Wed Jun 10, 2009 11:08 pm
Thanks guys.
I'll start with changing the lube, and if that doesn't help I'll change the stop ring and see how it shifts.
Ron Evans
67 Notchback
