It is currently Tue May 12, 2026 10:05 am
PostPosted: Thu Jun 11, 2009 10:33 am
i was getting tired of riding with no tunes in my 82 d-100.the radio in it was a electronic unit that worked when it wanted to.i went back into my stash of old car stereos and all electronic tune had succumbed to georgia humidity and no longer functioned. :(
but all was not lost.last time i went junkyard crawling i had pulled a factory mechanical tune am/fm out of an 81 truck.i spent a few hours pulling the old stereo and sorting out the wires and testing the old stereo.....it worked left,right,front,rear,balance,fader,adjustable button set(although one is a bit crooked).a triumph for the old style engineering.
now i just have to figure out where to install a pair of front speakers,since this truck only has a single dash speaker up front.i have a speaker box behind the seat that is providing most of the sound right now. :)
PostPosted: Thu Jun 11, 2009 3:32 pm
You could run 2 smaller speakers in the location of the 1 speaker...........
Wouldn't get any stereo seperation, but you'd be running with the 2 speakers.............
 Post subject: speakers
PostPosted: Fri Jun 12, 2009 11:05 am
http://www.slantsix.org/forum/viewtopic.php?t=34200 These look cool. They probably won't fit your truck, but maybe you could use the same idea.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
