It is currently Wed Nov 11, 2026 9:16 pm
PostPosted: Fri Jun 12, 2009 4:28 am
I know it's not an engine question, even though I do have a slant six engine. But I need to know the layout of the fuse box, so I can figure out what fuse does to what?
Thanks, John
PostPosted: Fri Jun 12, 2009 7:54 am
Go to http://www.mymopar.com/downloads/1976/76AspenA.JPG It has the wiring diagram for the 76 Aspen with fuse layout.
 Post subject: Fuse BLOCK
PostPosted: Fri Jun 12, 2009 12:21 pm
Do you know what fuse controls the radio? The wire coming to where the radio has no power. Help please.
Thanks
PostPosted: Fri Jun 12, 2009 3:28 pm
I've got a fuse block I pulled from an Aspen. Let me locate it and see what it says.
 Post subject: fuse box
PostPosted: Fri Jun 12, 2009 7:14 pm
OK Thanks
PostPosted: Fri Jun 12, 2009 9:36 pm
Does anybody knows if this wiring diagram is the same for
a 78 volare? or where can i find a fuse box diagram for
a 78 volare
thanks
PostPosted: Fri Jun 12, 2009 10:01 pm
Yes, they are both the same.
PostPosted: Fri Jun 12, 2009 10:51 pm
Just a thought, is it an aftermarket radio as they usually have an in line fuse in the power lead.
Thanks Mike
PostPosted: Sat Jun 13, 2009 5:39 am
Yes it is an aftermarket radio and the wiring kit does not come with an in line fuse. There are two wires coming out of the radio slot. An orange and a red, that is it. But neither of them have power. Any thoughts?
PostPosted: Sat Jun 13, 2009 6:29 am
If my memorie serves me right orange is the radio light and red should be power. Try testing the orange one when you have headlights on. The red one sounds like a fuse.
Thanks Mike
 Post subject: Fuse Block
PostPosted: Sun Jun 14, 2009 12:27 pm
The problem was that the fuse was blown. I actually replaced all the fuses, since they were probably the originals. Once I replaced the fuse I had power and now it is hooked up and sounding good.
Thanks for the help, John
