It is currently Tue Nov 24, 2026 2:46 am
 Post subject: P4529340 cam
PostPosted: Mon Jun 15, 2009 7:40 pm
Does anyone have experience with the Mopar Performance P4529340 hydraulic cam? Specs are lift .398", overlap 24, duration 240, centerline 106. I'm thinking of using it initially with a 2bbl carb, then eventually switching to EFI. Vehicle is a 67 Fury with 3 speed manual transmission, street driven.
 Post subject: Re: P4529340 cam
PostPosted: Tue Jun 16, 2009 4:35 am
Do you now have a solid lifter engine, or a hydraulic engine? If solid lifter engine, you will need to change the complete valve train. That cam is a very mild cam. What are your goals for the engine?
PostPosted: Tue Jun 16, 2009 5:11 am
Hydrolic cams didnt start until 1981 in slants.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
