It is currently Mon Nov 23, 2026 8:28 am
 Post subject: Super six hesitation
PostPosted: Wed Jun 17, 2009 1:02 am
1970 Plymouth Duster
PostPosted: Wed Jun 17, 2009 6:27 am
Get the "new" head and mount the super six like you sugested. Shaving the head and maybe putting OS valves in it will REALLY wake the old girl up.
I like to mount the manifolds on the head and then put the whole unit on the block( if I dont have the engine out). Remember to use brass nuts and antisieze on the threads of your "new" head. Then when you remove the old head you can work onit at your leasure.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Jun 17, 2009 8:24 am
Is there a kit with the bolts, nuts and washers on the market? I live in Sweden and I think I might need to order this.
Is there a particular head that I should keep extra look after, should I go with one from 1970?
Where can I order oversized valves?
Thanks for the reply!
PostPosted: Wed Jun 17, 2009 10:39 am
PostPosted: Wed Jun 17, 2009 11:42 pm
Thanks for all the usefull information! Now a can really get to start on this project!
PostPosted: Thu Jun 18, 2009 6:00 am
As for which head...68 thru 74 are a good choice.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
