It is currently Fri Jun 19, 2026 10:09 pm
Post new topic  Reply to topic  [ 35 posts ]  Go to page 1 2 3 Next
Favorite Fan Choice
Fixed steel four blade 33%  33%  [ 10 ]
Multi-blade flex fan 30%  30%  [ 9 ]
Clutch fan 37%  37%  [ 11 ]
Total votes: 30
 Post subject: Your #1 Fan
PostPosted: Mon Jun 22, 2009 9:03 am
Just curious what the comunity thought about the three different fan options for our daily driven slant powered vehicles with regard to cooling, horsepower gain/loss and fitment. Comments welcomed and encouraged, I realized that I have all three choices in my driveway. We'll leave electric fans and race vehicles off the table for now.
PostPosted: Mon Jun 22, 2009 9:17 am
Tough to find a clutch fan that'll fit the pre-'67 A-bodies. See here for discussion of clutch fans, here for info on a clutch fan that might fit, here for a discussion of flex fans, and here for a long discussion of faith vs. science in determining the effects of a fan swap. More threads and posts by searching flex fan with the board's search function.
How 'bout an electric fan with an upgraded alternator…?
PostPosted: Mon Jun 22, 2009 9:23 am
Dam, I couldn't find an emoticon to symbolize "raining on my parade", do you think you could help me out with that?
PostPosted: Mon Jun 22, 2009 9:45 am
Well, Kev and Nev at GPRS Mopar (the ones who make the nice Australian manifold gaskets) have said they're working on a clutch fan package that'll fit even the tight early engine bays, but then they have also said they'd work on a new-tech head gasket for the aluminum 225…
PostPosted: Mon Jun 22, 2009 10:45 am
I can't vote cause you don't have a "5 blade viscous" listed. Sorry
PostPosted: Mon Jun 22, 2009 10:47 am
"5 blade viscous" is a clutch fan. Go ahead and vote.
PostPosted: Mon Jun 22, 2009 11:11 am
Electric.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Jun 22, 2009 11:13 am
None of the above. I'm all electric too...
PostPosted: Mon Jun 22, 2009 11:51 am
No, there is no clutch. It's bolted directly to the pump.
PostPosted: Mon Jun 22, 2009 11:52 am
Then it's not viscous, but solid. "Viscous" describes the fan clutch.
PostPosted: Mon Jun 22, 2009 12:12 pm
Yes, I also consider "viscous" a clutch fan. As far as electric goes, I just wanted to stick with the water pump mounted variety. Not too many votes happening, are we all electric or just short on opinion?
PostPosted: Mon Jun 22, 2009 12:38 pm
I would never use a flex fan the last one I used was rated for 10,000 rpms and came apart at 6,000,puting a tear in my hood and a slice in my 150$ coil on my 73 charger :cry: :cry: :cry: the only perfect panel on a nice car. so my vote is clutch but a factory is fine if you don't mind exsesive drag
Nick
86 d150 turbo /6.
PostPosted: Mon Jun 22, 2009 3:19 pm
There is no one correct answer. Too many variables. What ambiant temp range? type of vehicle (light or heavy, radiator clearence), A/C or not? fan shroud? Auto or standard? Size of the radiator? any mods to the engine? final drive ratio?
In general, if there is room, I like a 5 blade thermal clutch fan.
 Post subject: Me too...
PostPosted: Mon Jun 22, 2009 6:02 pm
I have one of these off and the shroud off an Aspen on my duster, that is a pretty nice combination...much nicer than the 7 blade clutch fan...
PostPosted: Tue Jun 23, 2009 3:45 am
Electric
