It is currently Mon Jun 22, 2026 2:15 am
 Post subject: Oil
PostPosted: Thu Jun 25, 2009 11:20 pm
I just had my slant six rebuilt and I'am about to drop it back into my 1982 D-150. This might be a dumb question but I don't know what kind of oil to use. I was putting 10w-30 in it before I had it rebuilt. Do I just use the same oil?
PostPosted: Thu Jun 25, 2009 11:24 pm
That'll work.
Non syn for breakin
PostPosted: Thu Jun 25, 2009 11:43 pm
Do you need break in instructions, or did your builder supply you with that information?
PostPosted: Fri Jun 26, 2009 3:56 pm
I use Shell Rotella T 15-40 for break in, and at every oil change. It has all the good stuff that you need with a solid lifter motor. The newer synthetics are okay AFTER break in, but to be safe i would use some oil additive that you can buy from comp cams
PostPosted: Sat Jun 27, 2009 9:35 am
I would use 10-30 Rotella. 15-40 is OK for summer. 15-40 Valvoline diesel in my van makes noise in the TN winter until it warms up.
Too thick causes loss of MPG.
One thing for sure diesel lube will keep the insides clean!
 Post subject: Engine break in
PostPosted: Sat Jun 27, 2009 10:18 am
The machine shop that did my rebuild said they would not warranty the motor unless I used Kendal brand (diesel oil). It is very common up here and is similar to Rotella. So I followed their advice for the 20 minute 2,000 rpm break in procedure. After that I switched to 10-30 Valvoline for the next few months while the rings seated, then made the switch to 0-30W Mobile 1. Wow! what an oil!
The engine runs super quiet and gets incredibly fast oil pressure with a stock pump. Two seconds after start up I see 50 lbs. on the gauge. :)
PostPosted: Sat Jun 27, 2009 11:48 am
Are you using that 0W-30 in the summer time and if so, how hot does it usually get where you are?
Right now I'm useing a 10W-30 in mine and after a pretty hard run on the freeway, I'll still be at 50psi of oil pressure at an idel. I'm at 60-65 crusin' down the road.
I'm thinking on going to a 5W-30 to take a little of the pressure off of things...
Phil Hudlow 6678 S/C, S/G, ET
PostPosted: Sat Jun 27, 2009 12:43 pm
These recommendations are okeh for an engine in reasonable but moderately-worn condition. They are unjustifiably thick for a newly-rebuilt engine. Use 5w-30!
 Post subject: Re: Engine break in
PostPosted: Sat Jun 27, 2009 12:44 pm
That kind of requirement is illegal under the U.S. Magnuson-Moss Warranty Act unless the machine shop provides you with Kendall oil free of charge.
PostPosted: Sat Jun 27, 2009 2:20 pm
Dan,
Yes, they filled the crank case and pre-lashed the valves for start up. I just had to add another quart once it was in the car.
Last edited by Aggressive Ted on Sat Jun 27, 2009 2:30 pm, edited 1 time in total.
PostPosted: Sat Jun 27, 2009 2:30 pm
Hudlow6678,
Where we live against the foot hills it gets 85 to 95 quite often in the summer and occasionally a 100 for a week or so. In Seattle it might only get 75 or 80 degrees.
Dan suggested that I try 5-30W Mobil 1 in the summer which I have done but, there is something unique about the 0-30W Mobil 1. I am not sure what they do to the oil, but the engine really likes it year round. :shrug:
It runs cooler, quieter and has higher oil pressure quicker during the morning start ups and after heat soak. Plus the engine gets a little better mileage. I am thinking of just staying with the 0-30W Mobil 1. :D
PostPosted: Sat Jun 27, 2009 3:35 pm
No reason not to use 0W30 year round if your engine develops good oil pressure with it.
PostPosted: Sat Jun 27, 2009 4:03 pm
The viscosity of 30-weight oils (0W-30, 5W-30, 10W-30, 30) is all in the same range (9.3 - 12.5 cSt) at operating temperature (100°C). Lower W-grades (cold viscosity rating) are thinner compared to higher W-grades when the engine is cold. Therefore, your engine should have about the same hot oil pressure no matter which 30-weight oil you use.
Generally, a 0W-30 oil will maintain its hot viscosity better than a 10W-30 or straight SAE 30 because it of its higher viscosity index.
Engine Oil Article
