It is currently Sat May 23, 2026 9:18 am
 Post subject: 76 or 86 slant?
PostPosted: Fri Jun 26, 2009 9:23 pm
My grandpa has informed me that one of his friends just bought a dodge truck that has a slant 6 with a 4 speed in it, and he can't remember if he said the truck was a 76 or an 86. He wants $100 bucks for the motor, I dont know if this includes the trans or not (assuming it is though), but it runs. Now would this be worth buying more if its a 76? Also what are some of the avantages/disadvantages if its an 86 or a 76? I would like some opionions so I dont waste my time going to look at it.
Also, would a truck a833 fit in an a-body? Im assuming its a np trans, which I would not want in a car though.
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Fri Jun 26, 2009 10:01 pm
'76 is solid lifter. '86 is hydraulic and the hydraulic cam in pretty wimpy. The '76 may be forged crank or it may be cast. '86 is cast. Nothing wrong with the cast crank. In fact it's lighter and revs a little quicker.
The long A833OD can be made to fit, but it's work. Read the 4-speed article. http://www.slantsix.org/articles/4-spee ... speed1.htm
PostPosted: Sat Jun 27, 2009 10:18 am
$100.00? who cares, just buy it. Especially if it runs and has the trans attached. Sooner or later these motors will start to run out.
PostPosted: Sat Jun 27, 2009 6:52 pm
Is the hydraulic ok to use everyday, because I dont want to hassle with it, Im planning on swapping it into my car, because my current one runs a little rough. Also, can my 74 tune up stuff (cap, rotor, etc.) swap over to the later engines?
PostPosted: Sat Jun 27, 2009 7:29 pm
Yes.
Yes, but if the engine is an '86 you'll need to swap distributors. The spark plug wires won't need dust boots as the later head doesn't have spark plug tubes.
PostPosted: Sat Jun 27, 2009 9:56 pm
When Reed and I put the '83 engine in my Satellite, it ran just as well as the '73 engine I had in it. Same power, same mpg...just no valve adjusting, which is actually kind of nice for a daily driver. Hope you have better luck with yours...mine started smoking after a few months of use. The distributer, engine mounts, intake/exhaust, carb, power steering pump, everything will swap onto the newer engine. The lower alternator bracket will be different from cars to trucks, so you will also need to swap those over. You'll also need your car oil pan.
PostPosted: Sun Jun 28, 2009 5:10 am
whatever happened to that old 392 hemi you were working on last year?
What's that fuzzy blue thing being hurled this way?
::stick::
BOOSH!!!
