It is currently Thu Jan 01, 2026 9:03 am
PostPosted: Wed Jul 01, 2009 6:34 pm
Hello,
I have come across a 170 Block that has at least one freeze plug blown out of it and There is also a crack at the bottom of the water jacket along the Drivers side of the block.
Can hard block Seal p this problem say if 1/4 Inch of it was used to Seal the bottom of the waterjacket.
It would be nice to have the 170 Block But It's not work it if it's just scrap due to the Crack.
PostPosted: Wed Jul 01, 2009 7:46 pm
I wouldnt even think about building a motor around a bad block,its like building a house on a sandy foundation,you would constantly be thinking about it and worrying,I would,,,,,,,take your time and find a better block,My Opinion,Guzzi Mark
PostPosted: Wed Jul 01, 2009 8:39 pm
Grind a V shaped grove into the crack, break out the old gas torch and fill the grove with brazing rod. Should work just fine, by that is just my opinion...
PostPosted: Thu Jul 02, 2009 3:46 am
No, water will seep past the Hard Block.
170 blocks aren't that rare, wait on a good one. :shock:
PostPosted: Thu Jul 02, 2009 7:46 am
I have a 170 you can have but you'd have to pay shipping from MPLS/ST Paul.
PostPosted: Thu Jul 02, 2009 7:08 pm
my machieist uses a tap and taperd screws and a little jb weld.
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
Users browsing this forum: Charrlie_S and 5 guests
