It is currently Sun Nov 15, 2026 10:42 pm
PostPosted: Sat May 17, 2008 9:25 pm
Since the stock choke thermostat is no longer available, I put on an electric choke conversion today, the model 1232 from Randy Rymal. His website is http://www.rymalsrestorations.com/. I ordered it through his paypal account, classic301@aol.com for $55 shipped and got it in a few days.
It's a nice looking piece (see website) and it took all of about 10 minutes to hook it up and adjust it. The engine fired the first time and the choke released perfectly in a couple minutes. I'm impressed and very happy that I don't have to sit there pumping the pedal to get the car warmed up.
:D :D :D :D :D :D :D :D
70 Challenger (under resto)
70 Charger Daytona Clone (under construction)
70 Charger 383 (awaiting resto)
74 Duster /6
79 Li'l Red Express
'90 W350 Cummins
'93 D250 5.9L Magnum
PostPosted: Sat May 17, 2008 9:37 pm
Hooray! I like these units better than the stock type, too (and they're adjustable!). The writeup about them here on the site is here.
PostPosted: Sun May 18, 2008 6:11 am
Isn't it weird that carbs only sells Randy's product for less than buying direct from Randy?
PostPosted: Sun May 18, 2008 9:05 am
Not weird at all...he doesn't want to step on the toes of a distributor who buys more choke kits than he'll ever sell onesie-twosie to the likes of us! :shock:
PostPosted: Fri Jul 03, 2009 1:36 pm
I found this thread in the search for the solution to my electric choke problem. However I am wondering if there is a mechanical choke for the super six with a carter BBD that can be found in the boneyard. Is electric the only way they did it back then? If so is there an easy way to hook up the factory electric choke I currently have?
Dave
PostPosted: Fri Jul 03, 2009 2:18 pm
The '73+ "electric assist" factory chokes, I really don't like. They're not adjustable, they didn't work incredibly well when new, they work poorly when old, and they use parts (choke thermostat, choke heater modulator) no longer readily available. The electric choke kit is the easiest and cleanest setup to install, and it works well. You can cobble up a hand choke, but they don't work too well on carbs originally intended for use with automatic chokes.
PostPosted: Fri Jul 03, 2009 4:22 pm
Is the Randy Rymal choke something you've had good experience with? Any other options?
PostPosted: Fri Jul 03, 2009 4:28 pm
Uh...yyyyyyes?
(in context of this thread, and the linked one, this almost sounds a little like a trick question! :lol: ) You may have to disassemble it and flip the thermostatic coil over when you receive it; for some strange reason they sometimes come backwards. But that's the only real gotchya I've found. I've installed probably a dozen of these now, on different cars, and have found them easy and quick to install and adjust, and reliable in the long term.
Any other options?
New Old Stock original-type choke thermostat and modulator from Old Car Parts Northwest or elsewhere. Not as good of a result.
PostPosted: Sun Apr 03, 2011 12:04 pm
It looks like the website is no longer up. Does anyone know how to get one of these chokes these days. I see this thread is from 5 years ago.
Building my super six one screw at a time.
Make it faster!
PostPosted: Sun Apr 03, 2011 12:15 pm
Carbsonly Here
Super Six Conversion Stromberg
