It is currently Sat Nov 21, 2026 6:51 am
Post new topic  Reply to topic  [ 49 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sat Jul 04, 2009 8:34 am
If you don't mind me asking what kind of fuel system are you running as far as pump and fuel line size
Holley fuel pump (black) and regulator, 3/8" fuel line.
PostPosted: Sat Jul 04, 2009 9:05 am
That's enough for over 500hp if the pickup is also 3/8".
Since it will free rev, but breaks down under load I still think the ignition is breaking down.
PostPosted: Sun Jul 05, 2009 10:11 am
Didn't you rebuild the carb? Anything you changed is the most likely thing to look at. Does Charles have another carb you can bolt on there to see if it runs differently at least? I really like the hly 4412 500CFM 2bbl with an adapter plate you can get at Advance Autos (transdapt or Mr. Gasket).
I have seen too much OR too little timing give these symptoms too.
PostPosted: Sun Jul 05, 2009 10:36 am
The last time the carb was rebuilt it was rebuilt by Charles' guy.
I bought a new rotor and distributor cap to put on the car, When I put the new rotor on the car it changed the timing? That is strange...
PostPosted: Mon Jul 06, 2009 1:34 pm
Rotor/timing thing could indicate phasing is or was off in distributor?
PostPosted: Mon Jul 06, 2009 3:37 pm
It was off in the distributor...
PostPosted: Tue Jul 07, 2009 7:39 am
So is it running good now???
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Jul 07, 2009 10:11 am
Frank
It is running better, but still not right. We are going to tune on it Wed. and then head to Wilksboro on Saturday.
PostPosted: Wed Jul 08, 2009 9:09 pm
OK banging my head against the wall. We cannot get the car to start with 30 degrees of total timing we had to put 45 degrees of total timing for the car to start and run. But at 45 the car will not take a load, as soon as it is put into gear it dies. However once we start the car and drop the timing back, to around 30 it will take the load better. Any body got any ideas? Charles Myers has been a tremendous help to me but this has him baffled as well. It seems the more we try the worse it gets. I am looking for anything because at this point I am ready to pull the motor back out of the car.
PostPosted: Wed Jul 08, 2009 9:17 pm
When the engine was assembled were the timing marks verified with a degree wheel or piston stop as being accurate?
Have you checked the rotor to cap phasing? You'll have to sacrifice a cap and drill a hole in the top or side so you can see the rotor with a timing light.
Needing extra timing and having it die when in gear sounds like a vacuum leak or a cam timing problem. What's the cranking compression?
PostPosted: Wed Jul 08, 2009 9:45 pm
The timing mark was initially set with a degree wheel. We changed the balancer to an SFI balancer and rechecked TDC with a piston stop.
We have not checked the rotor to cap phasing, have not thought about it. This was the same distributor that was in my other motor that ran well and have not done anything but take it out of one motor and put it in another.
We have checked for vacuum leaks and cannot find any. We were potentially thinking it could be a cam timing problem, but it was degreed in with a degree wheel per the cam card from Erson. Unless we needed to do something different than what the cam card said. Anyone else using a .510 lift cam from Erson?
PostPosted: Wed Jul 08, 2009 9:47 pm
13.1 compression? what kind of fuel are you useing?
PostPosted: Wed Jul 08, 2009 9:50 pm
112 octane
PostPosted: Wed Jul 08, 2009 10:46 pm
Can you check the cranking compression?
PostPosted: Thu Jul 09, 2009 5:12 am
We checked it. I am not sure what it was because I was in the car, turning it over. Mr. Charles and my Dad were looking at it and said it was fine.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 5 guests
