It is currently Fri Nov 20, 2026 4:52 pm
PostPosted: Wed Jul 08, 2009 7:17 pm
OK, so what I'm hearing is that .100 off the block is not a big problem and I can go a little more if necessary.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Jul 08, 2009 7:23 pm
100 off is pretty standard.
PostPosted: Thu Jul 09, 2009 5:57 am
No problemo.
PostPosted: Tue Jul 14, 2009 9:22 pm
if the engine gets a full rebuild you could get the k-1 set up and with a clean up of the head and block .010 for each you'd end up with 10.5/1 with 55 cc combustion chambers. But if you have gone .060 over I guess other than one off pistions your build sounds good. What is the spec's on your cam?
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 6 guests
