It is currently Mon Nov 16, 2026 6:52 pm
PostPosted: Sat Jul 11, 2009 9:49 am
I bought a clutch kit for my '64 Valiant, and it came with two different bearing sleeves (the brass sleeve that pounds into the flywheel plate). One is a little longer than the other - this is the bearing that the end of the trans shaft slides into. My question - which one to use and how to tell? Will the longer one impede the trans shaft somehow? Any tricks for pounding that thing in? Thanks,
John in Colorado
PostPosted: Sat Jul 11, 2009 4:40 pm
If one is larger diameter it is probably for the unfinished cranks. It will drive into the register of the crank instead of the pilot bushing bore.
The smaller diameter one will drive into the pilot bore on the crank after you get the old one out.
PostPosted: Sun Jul 12, 2009 9:06 am
Hi Slantzilla,
The diameter of both bearings are the same, and they both fit nicely over the end of the trans axle. The length of one is slightly longer - about 1/2 inch longer. :roll: :roll: I can't figure out which one I should commit to driving in, knowing it will be a pain to pull it out if it is the wrong one.
John in Colorado
PostPosted: Sun Jul 12, 2009 8:51 pm
Ahhh, am I understanding that only the length is different and not the OD?
I would choose by the hole in the crank. If it is finished all the way down use the longer one.
