It is currently Sun Nov 22, 2026 5:20 pm
 Post subject: compression ratio
PostPosted: Mon May 05, 2003 8:51 pm
I need some help here. I have a head milled .080, motor bored out .060 useing a stock head gasket can anyone tell me the compression ratio. Compcams has a cam I am thinking of useing but the catalog says it is designed for ratios of 9.1 or less. Also has anyone ever used a marine cam? A buddy of mine made that suggestion, he used to race circle track and said that the cam he used. :?:
thanks for the help.
OD
PostPosted: Mon May 05, 2003 9:54 pm
If you "cc" the head and measure how far down in the hole the pistion is, we can figure the static CR.
Without those measurments anything stated would be a "WAG".
(my wild-a$$ guess is 8.8, do we hear 9...???)
PostPosted: Sat May 10, 2003 7:55 pm
My "WAG" would be around 9.4-9.5 :D
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Sat May 10, 2003 9:09 pm
The mairine cam was used as the standard cam from '71 to '77 in all slant six's.
Users browsing this forum: Google [Bot] and 11 guests
