It is currently Fri Nov 20, 2026 6:04 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Sat Jul 18, 2009 12:33 am
Thanks Rod, while searching I found the thread where you asked the question. Come on Dan, help us out. :)
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Sat Jul 18, 2009 6:31 am
You can run the washers or not. I have seen no performance/mileage difference whatsoever, except that your drool tubes might last longer w/o the washers due to wear on the aluminum.
Dan certainly distributes a huge volume of useful advice, which we are all grateful for. Certainly the plug part numbers and heat range info is useful. However, I do not believe Dan has developed or built performance Slant 6s or has likely been down a dragstrip. This is my impression and I don't know for sure. Personally, I take his performance advice with some caution. He can feel free to correct me if I'm wrong.
Best,
PostPosted: Sat Jul 18, 2009 6:57 am
No performance/mileage difference has ever been claimed. Please go read the thread with factory info on why '60-'62 heads run the washers and '63+ heads don't.
True.
False.
And clarifying muddled information on spark plug heat ranges is not really "performance advice".
PostPosted: Sat Jul 18, 2009 7:00 am
What are the Aussie Slant 6 heads classed as.........pre-'63?? I know we had Slants up till '69, but are ours all the same casting.
Donno. I can look in my VE-VF FSM next time I'm at the office. The casting number didn't change up here until '68, either; the spark plug seat change was made as a running change.
I'm asking because it seems everyone "down under" leaves the ring washers on their plugs.
Everyone up here does so, too, because the factory advice to remove the washers is no longer common knowledge.
PostPosted: Sat Jul 18, 2009 7:05 am
True.
False.
Dan
I merely stated that on a Preformance slant engine (which His is) the use of extended tip spark plugs is " at least under question and/or a bad idea due to Heat Build-up" not heat range of the plug.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
