It is currently Wed May 13, 2026 1:27 pm
PostPosted: Fri Jul 17, 2009 10:15 pm
So everyone has been so great, and I am near the end..... at least for now.....
All back together, oil pressure sender wire attached, and started the car and the exhaust was leaking like a son of a gun.... or so I thought......
Went through checked all my gaskets and torque specs and couldn't figure out the problem til I put my hand behind the exhaust near the firewall and felt a very strong warm breeze..... from a big freakin hole that my old manifold did not have......
Guessing EGR? What would you recommend to close it up? Just a bolt and Lock washer?
Thanks Again
Jeremy
And yes I am going to buy the books soon.... well once I find a job......
PostPosted: Fri Jul 17, 2009 10:20 pm
Yes, plug it with a brass plug if you can if not, use a stainless steel bolt and lock tight.
PostPosted: Sat Jul 18, 2009 4:20 am
There are a lot of hole plugging ideas in THIS THREAD.
Danny
PostPosted: Sat Jul 18, 2009 5:01 am
Car Model: '23 T-bucket
What the hell is THAT!? First time I've ever seen a threaded hole in that location. Is it supposed to be for an O2 sensor?
I suggest you figure out the threads and get a proper plug for it. If the plug has to be steel, put some copper-based anti-sieze on it before threading it in......and do the same for those bolts holding the exhaust pipe flanges together.
Roger
PostPosted: Sat Jul 18, 2009 6:24 am
thanks all
jeremy
PostPosted: Sat Jul 18, 2009 7:01 am
Yes, it's an O2 sensor port.
 Post subject: You could...
PostPosted: Sat Jul 18, 2009 8:57 am
Just put an O2 sensor in and wire it up to a gauge and see how your carb is doing (and use the data subjectively to dial in the mix and your timing a bit better...)
Users browsing this forum: Amazon [Bot], Google [Bot] and 7 guests
