It is currently Wed Nov 18, 2026 6:57 am
PostPosted: Thu Jul 16, 2009 5:19 pm
Yes, I am running a stock cam.
Way back when I originally purchased the Offy dual Weber setup, the two carbs together were supposed to be around 400 cfm. I don't know how accurate that is though.
She's running better since I fixed the vacuum leak though.
'78 Volare 225
'67 Charger 318
PostPosted: Sat Jul 18, 2009 11:08 am
Well, I emailed Pierce Manifolds and asked them about the cfm on this carb (Weber 36DCNVH), but I haven't heard back yet. I've fiddled with the idle mixture some more, and it's running better. We'll see. My Volare is starting great and running better now, so I may just be happy with this carb.
'78 Volare 225
'67 Charger 318
PostPosted: Mon Jul 20, 2009 7:07 pm
as a former dealer and installer for Weber, get you a 38 DGEV, a straight up 2 barrel. BUT make sure you have the intake for it. A true 2 barrel intake with a non restrictive adapter plate or direct bolt on. If using an adapter plate, make sure its not an open one (one big hole) use only a 2 hole and look to make sure the holes are 38 mm .
PostPosted: Tue Jul 21, 2009 3:01 pm
Thanks for the advice.
I'm curious about what you said about not using an open adapter plate, could you elaborate a bit?
Thanks! :)
'78 Volare 225
'67 Charger 318
