It is currently Wed Nov 11, 2026 6:30 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sat May 09, 2009 7:12 pm
Looks just like mine as well.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun May 17, 2009 8:16 pm
In case anyone else runs into this situation; on this starter if you break the plastic off you will find it goes "into" the starter (like I thought) I went junking a couple days last week; everything I found was either (1) already missing (you know how junkyard people remove parts; cut-snip-hack) or (2) not the right plug or (3) basically inaccessible to tell; I checked out LH cars minivans and a couple 2000+ B vans which, all had their engines/trannys missing and some Grand Cherokees and came up empty;
The solution? I guess theres some sort of "retro fit kit" to be able to wire up this 2000-2003 spec starter available from Mopar; somewhere around $14-18ish, (cheap considering that I got this new starter for free)
No PN yet or description, til it arrives Tues. At this point IDK if its just that pigtail, or what.
PostPosted: Thu May 21, 2009 12:55 pm
I have a starter like this too. I have not found the factory connector, but I do have the correct fitting crimp connector.
It is a weatherpak terminal, you can get them in small packs without the plastic plugs.
I am just going to crimp and solder it to a new wire, put a little vasaline on it and plug it in. It can be sealed with silicone after that which will also hold the wire on. This could be a pigtail that attaches to the factory wire so any other style starter can be swapped out. I'm just trying to keep it simple.
PostPosted: Thu May 21, 2009 5:14 pm
I got the "starter wiring adapter wiring kit" from the stealership parts counter today. A pigtail ~6" long with the weatherpak connector+ a pc of Shrink Wrap+ a "splice band (a "V" shaped piece of brass about 1/2" square to splice it to the OE "Sol" wire, and an inst sheet that tells the Miller tool number for "their" crimp tool. Personally I prefer soldering.
I certainly would not pay $19. for it (MSRP) but for "employee" price (I know a few) I got it for ~2/3 that; MSRP is a rip as far as this pigtail is concerned; but then compared to what the starter lists for (and being that I wound up with that for free :P ) I guess that still wouldnt be too bad, "big picture" wise.
In case anyone's interested; the Mopar PN is; 5014098 AD
PostPosted: Sat Jul 18, 2009 6:19 pm
These jap starters are fine, IMO. Just be sure and stay far away from the china made starters- They have cheap casings that crack.
PostPosted: Sat Jul 18, 2009 6:49 pm
I got the pigtail from wermopar.com for about 14.00. I also bought a dipstick for the Dakota at the same time. Shipping for both items was 10.00.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
