It is currently Tue Nov 17, 2026 11:49 am
 Post subject: Cam Recommendation
PostPosted: Sun Jul 19, 2009 11:50 am
I was wondering your thoughts on an Erson cam selection. I have a 225 that will have a super six set up on it, big valve head with a port and polish job. I with eventually go with a Dutra duals 2 into 1 exhaust. I am going to shoot for a 9 - 9.5 to 1 compression ratio. The axle is 7 1/4 with 2.76 ratio. I am at present thinking of going with the RV15/244 combo. I just wanted to get some input before ordering. Thanks in advance Mike
Thanks Mike
PostPosted: Sun Jul 19, 2009 2:37 pm
Considering you are running the 2.76 gears, the cam you selected seems like it would work great. With your headwork, I could see it being a nice streetable package with a nice low end torque curve for street driving.
 Post subject: E254 grind
PostPosted: Sun Jul 19, 2009 3:04 pm
I am using the E254 grind with a 8 3/4, 2.76 Auburn posi in a 3600 pound car and find it to be a very powerful combination. Been running it for almost 3 years now. Around town is 23.5 mpg, trips are 25+ mpg on regular gas. The biggest effect in power comes from advancing the cam 4 degrees and recurving the distributor.
PostPosted: Sun Jul 19, 2009 7:27 pm
Im at the other end with the 280/270 cam. It seem to work great for that build.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Jul 19, 2009 8:42 pm
Hey Ted, sounds like he's building a carbon copy of your motor. better warn him about that 7 1/4!!
To each his own (so what if I wanna build a 450 horse MPFI turbo /6 instead of using a V-8!)
PostPosted: Sun Jul 19, 2009 9:02 pm
I've already got my eyes out for a 8 3/4. As soon as I find one close by it will be mine. :lol:
Thanks Mike
PostPosted: Sun Jul 19, 2009 10:18 pm
Mike,
Very good! With the new found torque you will be much happier with a 8 3/4.
I even went as far as to use the 489 case... It will still twist even with the new 5 leaf springs. It is time for me to find a pinion snubber.
Anybody have a spare?
PostPosted: Mon Jul 20, 2009 5:21 am
Will you use a higher stall converter? Personally, I would get the 280/270 cam and use a 26-2800 RPM stall converter.
PostPosted: Mon Jul 20, 2009 6:29 am
Yes a higher stall converter, shift kit and, rebuild of my spare tranny are in the plans. :D
Thanks Mike
PostPosted: Mon Jul 20, 2009 6:43 am
In that case, the smallest cam I would even consider is the Erson 270/270, but the 280/270 will likely be better.
PostPosted: Mon Jul 20, 2009 8:29 am
Lou and I are always on opposit ends of cam selection... he tends to lean to the "big is better" side and I tend to go with as small as possible... to get the job done.
For the discribed combo... with 2.76 gearing, keep the cam small to get more torque in the lower rpm ranges.
You will also have to watch the amount of stalll speed you use with the high rearend ratio. The converter needs to be off it's stall at your freeway rpm and I bet that is somewhere in the 2600-2800 rpm range with the 2.76
PostPosted: Mon Jul 20, 2009 2:29 pm
Mike,
As a reference: 2200-2500 rpm is cruise at 60 mph depending on the grade on my Dart running 14" P225-60 BF Goodrich T/A Radials with a 2.76 8 3/4" posi.
With a 2.76 on the back roads where folks go too slow (30 to 40 mph) it is hard to keep at rpm to keep the converter locked at light throttle settings. If all you do is drive on freeways, then getting good mileage is much easier.
PostPosted: Tue Jul 21, 2009 6:27 am
It kinda an East vs West thing. :lol: :lol: :lol: :lol:
Interesting enough is BOTH ways work,IF, you choose the rest of the combination correctly.
My 02.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Jul 21, 2009 6:57 am
Gee, Doug, and I was going a little milder here... :wink:
In my experience a 2800-3000 stall (modern) converter will act almost just like a stocker until you stand on it, and then you will have the stall. I saw *maybe* 0.5-1 MPG drop going from a stock converter to a 2800 in mixed driving.
 Post subject: Oh No!
PostPosted: Sat Jul 25, 2009 12:13 pm
Houston we have a problem! We have 2 geniuses and they disagree! I gotta look outside it must be snowing in July. :wink: :wink:
Rick
Users browsing this forum: No registered users and 16 guests
