It is currently Sat May 09, 2026 1:45 pm
Post new topic  Reply to topic  [ 180 posts ]  Go to page Previous 13 4 5 6 712 Next
PostPosted: Mon Jun 01, 2009 12:22 pm
Several 8.30,s @ 80 Irwindale 1/8th mile,will start tuneing and playing with a few things,8.20 is my goal with THIS motor,Guzzi Mark
PostPosted: Mon Jun 01, 2009 1:13 pm
***9 Second Zone***
9.85 @ ??? The Drakes, 1938 Simca
9.93 at 132 Charles Myers, Plymouth Arrow, 6/21/2003
9.97 @ ??? Cox Bros, 66 Dart
***10 Second Zone***
10.19 @ 129 Mike Jeffrey and Blaine Mueller's "Buzzin' Half Duzzin' 1968 Valiant
10.5 @ 127 Will 67 Barracuda methonal & nitrous with Cam2 enrichment July 2004
10.900 @ 124.24 - 1.57 60', turbo66valiant, 66 Valiant Signet, 2750# w/o driver, turbo, intercooled, 727, 2.94, AV gas, May '09.
***11 Second Zone***
11.529 @ 112.34, 1.53 60', Exner Geek, 62 Valiant, 2300#, 904, 4.56, Webers, on gas, Nov. 2007
11.54 Dave Mueller Alchohol Injected (C/Alcohol Record)
11.88 Ron Hamby at Hamilton Oh. 2004 '66 Dart on NOS
11.98@109 turboram (Nick Stamm) 3600# 86 ram missing like heck!!
***12 Second Zone***
12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02@ 107mph Ron Hamby at ClayCity Ky. 2008 '66 Dart on Alky---
12.32 @ 110.25 Shaker223, 1.85 60', Stock Slant 6 with turbo, 1970 Swinger, 2.94 gear, May 2009
12.33 at 107.88, Samoa, SwinginSixAric
12.54 @104.63 mph Valdosta 2008 Ron Parker
12.77 @ 105, Doctor Dodge - 62 Lancer, MATS 2009
12.98 at 101.03 at Redding, "Wayne's World" 170 cu inch (on gas) 62' Valiant -Wayne Erickson-
***13 Second Zone***
13.39@96 sgtmcd42, Crooked 6, red light lifted @ 1000'
13.58@100 Kidd 62 Valiant, MATS 2009
13.76 @ 99.41, 1.90 60', Exner Geek, 62 Valiant, Street Driven, 2800#, A833OD 3.73 gas, June 2008
13.86 @ 95.82 Madmax/6, Las Vegas MATS 2009
***14 Second Zone***
14.095 @ 93.14 Old6rodder, HA/GR, "Barn Job #18"
14.15 @ 91.02 Crazy Dart (converted from 1/8mi) 67 Dart,904, 3500 stall, 4.30 gear. 5500 RPM.
14.206 @ 94.76mph 2.05 60' METALSKIN draw thru turbo slant (9psi) AP5 valiant 2.9
14.30 @ 96 MPH Lou Madsen '64 Dart 270 in street/strip trim in 1997 at Pomona Dragway (904w/3400 stall, 14" Radial TAs, 60 over cast pistons)
14.57 @ 94.6 MPH, Lou Madsen '64 Dart 270 in street/roadrace trim, 2009 at Mason-Dixon Dragway (T5 trans, 16" autoX tires, 60 over cast pistons)
14.743 @ 89.81, 1.931 60' Bren67Cuda904, 258 ci Slant (Eileen) 3400 lbs with A/C, Gear Vendors, Full interior including Child car seat, 8 1/4, 3.55
14.79 @ 93.56 Greg Ondayko
***15 Second Zone***
15.34 @ ?? Brian '74 Duster,1971 225 block ,.100 off blk, .100 off head,MP 528" lift cam with 284 duration, 904,4.10
15.39 @ 87.32 Fopar May/4/08 3400lb 53 Ford 225 bored .030 .090 off head custom cam custom headers 904/4.11's
15.40 @ 89 mph Lindross, roadster
15.6 @ 90 MPH - '68 Dart street car - Lou Madsen - 1996 at LA Cty Raceway
15.501 @ 88.83, SV162, May 2008
15.82 @ 84.32 1974Duster Kev- Converted from 1/8 mile numbers
15.855 @ 87.25, Rob Simmons, '73 "GodsRods" Duster, 28 May 06 @ SGMP, just under 2,785 #
***16 Second Zone***
16.35 @ 81.3 70valiant', 3.23
16.51 @82.2 Ceej in the Hooptie Redding
16.59 at 81.68mph TRYSIX '65 Coronet 4dr, Isky cam 228/448
16.707 @ 82.11 Mike Andreas,225 cid block +30. Stock pistons .100 off the deck. Isky 448 lift, 4 speed
16.868, 80.06 MPH J. Skinner '67 Valiant 100 3-speed, stock short block
16.89 @ 78.49 3.23open 75 duster (Wicked/six)
***17 Second Zone***
17.20 @ 85 The Black Sheep
17.27 @ 79.03 Featherduster76(converted from 1/8mi) 71 Duster 225/904
17.29 @ 78.66 Rhonda Amis '66 Valiant Signet 200 225ci,904 MATS 2009
17.44@78 Slant Cecil '68 Signet 225, 904 ,2975lb w/driver ,140K mile motor with 6x1 header, BBD, electronic ign ,4400rpm shift
17.72@77 Nick Bowman 1970 Plymouth Duster 2bbl-904-3.23
***18 Second Zone***
18.312 @ 72.31 Vallyant
18.832 @ 72.82 Dodgegirl
***19 Second Zone***
19.05 @ 73 Davids63Dart, September 2007
19.21 @ 70 Doc, 65 Dart GT Convertible, stock alm block 225 ,1bbl Carter, Dutra dual exhaust, 904 auto. trans., 2.94 8 3/4 rearend.
19.35 @ 69.85 THOR, '74 Swinger, Redding Dragstrip (Stock Cast crank-juice engine... stock 2.76:1 "SG") 10/25/08
19.52 @ 69.26 Slanted66, Altitude 5300 ft (Headers, Isky cam, 1bbl, 904, 3.23s)
19.6 @ 71 eightymopar , 1980 Cordoba
***20 second Zone***
22.18 @ 60.6mph 72polara, '73 /6 Swinger stock and wore out
 Post subject: Added Ryan Covalt 14.84
PostPosted: Mon Jun 01, 2009 6:43 pm
***9 Second Zone***
14.84 @ 91.22 Ryan Covalt 72 Swinger 3170#/ w/o Driver, Mason Dixon
May 31,2009 1st time out. 4.30's, 4 sp.OD, street slicks
PostPosted: Tue Jun 09, 2009 6:12 pm
Would like to see some 1/8th mile times,Guzzi Mark
PostPosted: Sat Jun 20, 2009 8:45 pm
Site Admin
***9 Second Zone***
15.803 @ 86.33, Ceej, Hooptie, Woodburn
PostPosted: Sat Jun 20, 2009 8:54 pm
***9 Second Zone***
16.33@79.81 DusterIdiot, Woodburn...still sorting out the new motor
PostPosted: Fri Jul 10, 2009 6:44 pm
***9 Second Zone***
19.78 @69.56 1980volare, 1980 volare,bbd 2.76,28" tires,stock exhaust.
 Post subject: 19 second zone
PostPosted: Sun Jul 12, 2009 11:18 am
19.37 @ 69.77 Aggressive Ted, '74 Swinger, Pacific Raceways, (3600 lbs. #56 jet/1920 Holley, 8 3/4 2.76:1 "Posi") 7/11/09
First time out so don't laugh too hard. I could spin the tires off the start with the pump shot but then it would just flatten out and go at a steady rate. Definitely need to try some bigger jets next time but this was Bracket Race #8 so I just went with the way it was, tuned for 25+ mpg. I think this engine build has some potential given a freer flowing muffler and a four barrel and some lower gears. I definitely need a spare 489 posi with some lower gears.
I made it four rounds then broke out by going faster than my dial in. As the night went on it just hooked up and ran faster. Live and learn....... It's an addiction! :)
This is the "Torque and Mileage" engine build recipe from Doc.
Pacific Raceways is in 31001 144th Ave SE Kent, WA 98042-4601 www.pacificraceways.com It used to be called SIR a few years back.
PostPosted: Sun Jul 19, 2009 5:00 pm
Site Admin
***9 Second Zone***
15.66 @ 87.87, Ceej, Hooptie, Woodburn 7/19/09
16.31 @ 79.81 DusterIdiot, Woodburn...still sorting out the new motor
PostPosted: Sun Jul 19, 2009 6:26 pm
6 Pack Dart
***9 Second Zone***
14.975 @ 89.70mph "6 Pac To Go" (Fopar's Mopar) '63 Dart GT Woodburn 7/19/09
PostPosted: Mon Jul 20, 2009 5:53 am
***9 Second Zone***
13.37 @ 98.33 Charrlie Schmid, 66 Cuda 170cid
14.975 @ 89.70mph "6 Pac To Go" Fopar's Mopar '63 Dart GT Woodburn 7/19/09
PostPosted: Thu Jul 23, 2009 4:06 pm
SL6 Racer
***9 Second Zone***
15.12 sergio 7/11/9 samoa stock engine 3.91 hedder ,5002 bl.big converter
 Post subject: Added my times
PostPosted: Fri Aug 07, 2009 9:30 am
Car Model: 69 Valiant
***9 Second Zone***
15.12 sergio 7/11/9 samoa stock engine 3.91 hedder ,5002 BB converter
15.20 @89 Joel Harris 69 Valiant, 225 stock bottom end, .100 off head, 2bbl, pump gas, mopar268 cam, headers, stall, 3.91, 904, 2750# w/o driver, mostly stock driver
 Post subject: More updates coming
PostPosted: Sun Aug 30, 2009 4:37 pm
***9 Second Zone***
16.281 @ 82.64 DusterIdiot, Medford, Hpak Duster Holley Annular 600, 3400 lbs
PostPosted: Sun Aug 30, 2009 6:58 pm
***9 Second Zone***
14:91@88-Little Red Piggie on muscle only-US41 8/29/09
