It is currently Tue Nov 17, 2026 2:11 pm
 Post subject: old distributor
PostPosted: Sun Jul 19, 2009 5:35 pm
picked up an old slant distributor, points type,, wondering how old it is,
numbers stamped into the housing
1889750 C 21-1 (although the 4th digit could be an 8)
got it for free, just wondering what it may be from,
thanks
PostPosted: Sun Jul 19, 2009 6:06 pm
1889750 was the first-year (1960) 170 slant-6 distributor.
PostPosted: Mon Jul 20, 2009 4:30 pm
thanks
any difference in a 170 and a 225 distributor,, in other words, would this work in a 225,,
I thought about cleaning it up and just keeping it around as a back up
 Post subject: Re: old distributor
PostPosted: Mon Jul 20, 2009 5:26 pm
thanks any difference in a 170 and a 225 distributor
Different advance curves. 1960 225 distributor was 2095 270.
Yes, all slant-6 distributors are physically interchangeable.
 Post subject: 60's points distributor
PostPosted: Sun Oct 04, 2009 6:21 pm
Been accumulation a lot of part to make this old slant go,, as a first step and also just for the fun of it, put in this 1960 points distributor as the first change . Rounded up a new set of points then stripped out the Lean Burn wiring and using the original coil put the points distributor in.Guess the old Lean Burn was Really Burnt. With the Lean Burn system, winding the motor out to much above 3500 RPM resulted in a lot of thrashing but not much go,,, with the 60's points distributor I can really feel the motor pull up to 4500 rpm,, not fast by any stretch, but it does accelerate. Did the swap about a month ago, fuel milage is about the same, starts good, idle is smoother,, biggest difference is a bit more power up through the gears.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
