It is currently Tue Nov 17, 2026 1:01 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
 Post subject: 1980 Volare
PostPosted: Wed Jul 22, 2009 9:44 am
I will check tonight on what muffler Magnaflow it is and let you know tomorrow.
PostPosted: Thu Jul 23, 2009 6:45 am
Greg where are you getting your numbers? With .210 off total you will be alot higher than 10 to 1. Im at better than 11 to 1 with .150 off. And for most combinations .100 off(in what ever combination you want) is about the max before you need push rods.
My02.
Frank
Well I never Officially CC'd My heads So I really do not know. Maybe my engine is higher than that.
Greg and Others
FYI .100 off the head yielded 37.5cc volume with the "Ford 300" 1.78/1.50 valves NOT recessed (sunk)into the head. The ZFR5N extended reach plugs decrease your cc's by exactly 1/2 cc.
This was on a 74 head. I cannot tell you if the head was cleaned up prior to this or not.
Just for reference PLEASE measure.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Jul 26, 2009 2:39 pm
After reading everything in this forum, I decided to wait until the season is over and rebuild the entire motor. I've been told various things but it seems consistent that milling the head and decking the block are no problem. Have any of you used Cliffords rebuild kit which includes a hp cam? $800 for a rebuild kit and cam seems very reasonable.
PostPosted: Mon Jul 27, 2009 6:59 am
You can do alot better than that. PAW and Others out west. Use Erson for cam. springs, lifters, locks and keepers. Engine Builder for valves.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: To: SlantsixDan
PostPosted: Wed Jul 29, 2009 9:34 am
Dan, you mentioned recurving the distributor. Can you explain what that means and what is entailed? Thanks, Dave.
