It is currently Tue Nov 17, 2026 5:28 pm
PostPosted: Tue Jul 21, 2009 8:47 am
ok heres my dilema lol. im lokkin to buy a 71 slant six for my 84 dodge d100. the slant six has a automatic trans on but my truck is a manual. i've heard that the input shafts are different and it wont fit. anybody have any input?
PostPosted: Tue Jul 21, 2009 9:27 am
Your answer lies somewhere in the transmission section of the forum.
A quick search yielded these threads:
http://slantsix.org/forum/search.php?mode=results
If you can't find it in those try different key words.
I wish I knew the answer for you.
EDIT: I thought I could link the search results for you. Oh well, there is the page to do your searching!
Chris'
Autobody
Restoration
Service
PostPosted: Wed Jul 22, 2009 5:15 am
Crank sizes changed in 67. When the cranks went to cast in 81 the register stayed the same.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Jul 22, 2009 5:29 am
You may be refering to the fact, that the small bore in the end of the crank, may not be finish machined for a pilot bearing. Not a big deal, NAPA sells a "problem solver" pilot bushing, (slightly smaller OD), also I understand you can use the pilot bearing from a late model V-6 or V-8, I think from a late 90's.
PostPosted: Thu Jul 23, 2009 11:40 am
ok so if i buy a another slant six out of an automatic car ffom the 70's i'll be good for my 84 A833 4sp?
PostPosted: Thu Jul 23, 2009 10:33 pm
It should be, but as mentioned above, the rear end of the crankshaft is bored out to accept the torque converter hub and may not be bored deeply enough to allow the A-833's input shaft to slide all the way in. IF this is the case, you can shorten the input shaft end and use the modern roller bearing type input shaft sleeve, which fits right into the toque converter hub bore on the back of the crankshaft.
My '77 /6 accepted my '80 A-883 without any issues.
PostPosted: Fri Jul 24, 2009 6:57 am
I would say you have a really good chance of it working without a hitch. BUT if it doesnt its can still made to work without any major problem. Cutting the shaft is no worse than putting in a trans or engine. So go for it.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: bushing
PostPosted: Sun Jul 26, 2009 9:18 am
I agree with 66 cuda,I have 8 69-73 model year (forged crank) engines.All were removed from auto trans cars,all of them were machined for a stick trans,and even had the bushing installed! In the very unlikely chance that you do get in a bind,Mopar action june 1999 had the articule In the pink is describing. :D
